Author Topic: make a function  (Read 1889 times)
AIberto
make a function
« on: July 11, 2015, 05:17:51 AM »
_1$ (setq item "HKEY_CURRENT_USER\\Software\\Data")
      (mapcar '(lambda (x) (vl-registry-read item x)) (vl-registry-descendents item ""))
returns
("134" "500" "530" "540" )
I don't know what is  this  value ?  I need know keynmame
so
_1$(setq item "HKEY_CURRENT_USER\\Software\\Data")
     (mapcar '(lambda (x) (list x (vl-registry-read item x))) (vl-registry-descendents item ""))
returns
(("Width" "134") ("Length1" "500") ("Length3" "530") ("Length2" "540"))
Is it possible? Defined a Function
( defun get_reg_lst ( patch keylist)
call :
(get_reg_lst  item  '(Length1  Length2 Length3))
returns
( "500" "540" "530" )
« Last Edit: July 11, 2015, 05:21:46 AM by AIberto »
kpblc
Re: make a function
« Reply #1 on: July 11, 2015, 08:20:36 AM »
(mapcar '(lambda (x) (cons x (vl-registry-read item x))) (vl-registry-descendents item ""))
Sorry for my English.
AIberto
Re: make a function
« Reply #2 on: July 11, 2015, 10:03:40 PM »
Not I want ,
Hi kpblc ,You didn't see this one ? It's the same.
so
returns
This is I want.
call :
returns
kpblc
Re: make a function
« Reply #3 on: July 12, 2015, 12:19:35 AM »
There are many ways to get what you want:
      lst  '("Length1" "Length2" "Length3")
      ) ;_ end of setq
(vl-remove-if-not
  (function
    (lambda (x)
      (member (car x) lst)
      ) ;_ end of lambda
    ) ;_ end of function
  ) ;_ end of vl-remove-if-not
(mapcar
  (function
    (lambda (key)
      (cons key (vl-registry-read item key))
      ) ;_ end of lambda
  ) ;_ end of mapcar
and more ways. Unfortunally i have no time to write them (and i think you can create some more ways and codes ;))
AIberto
Re: make a function
« Reply #4 on: July 12, 2015, 07:46:40 AM »
      ) ;_ end of setq
(vl-remove-if-not
  (function
    (lambda (x)
      ) ;_ end of lambda
(mapcar
  (function
    (lambda (key)
      ) ;_ end of lambda
  ) ;_ end of mapcar
Thank you kpblc
  1.     (lambda (key)
  2.       (cons key (vl-registry-read item key))
  3.       )
  4.     )
  5.   '("Length1" "Length2" "Length3")
  6.   ))
  7.
  8. ("100" "200" "300")
  9.
kpblc
Re: make a function
« Reply #5 on: July 12, 2015, 08:00:03 AM »
you can make code more simple:
(mapcar
  (function
    (lambda (key)
      ) ;_ end of lambda
  ) ;_ end of mapcar
But i prefer to proceed with dotpairs and use assoc function: codes used this method are more scalable and clear.
