Author Topic: Check data ,Return "T" or "nil " I'm in trouble  (Read 5268 times)
AIberto
Re: Check data ,Return "T" or "nil " I'm in trouble
« Reply #15 on: July 15, 2015, 10:01:52 PM »
Code at #3 returns T. Is it correct?
Dear kpblc,
eg: data.txt
ABCDEF123
0
3012400
3024000
If I want  only change the value of Second row , Other values unchanged
Have a quick way ? Thanks.
You would need to read & re-write the file, e.g.:
Very Thanks , Lee .  :angel:
I think the wrong,I thought , if the value unchange, so no need rewrite .  :embarrassed:
Lee ,Good function , (setq lin (1- lin)) good idea.
I learned a new function "foreach"  , foreach is  like DOS command " FOR"  :lmao:
« Reply #16 on: July 15, 2015, 11:53:00 PM »
« Reply #17 on: July 16, 2015, 07:46:34 AM »
HINT: Look in CADR & SUBST
Thanks ,ronjonp , SUBST  is useful !
Just be aware that subst will substitute ALL occurrences of the item, not just the second line.
« Reply #18 on: July 16, 2015, 08:53:07 AM »
Good to note Lee  8)
AIberto
« Reply #19 on: July 16, 2015, 09:00:25 AM »
Thanks again , Lee , I haven't test with "SUBST" , Thanks for reminding .
« Reply #20 on: July 16, 2015, 12:53:26 PM »
e.g.:
  1. _$ (subst "a" "b" '("b" "c" "d" "b" "e"))
  2. ("a" "c" "d" "a" "e")
Good to note Lee  8)
Cheers Ron  :-)
