Author Topic: Download trial versions  (Read 2712 times)
« on: July 08, 2015, 11:20:49 AM »
I am trying to download the trial version of Civil3D 2016. I managed to get the Autodesk Download Manager installed but is far as i can get. If I try again, from the web page the dialog bog says "8 errors" and stops working. *shrug*
Has anyone successfully downloaded and installed a trial version?
Re: Download trial versions
« Reply #1 on: July 08, 2015, 11:22:11 AM »
a picture is worth ...
« Reply #2 on: July 08, 2015, 11:49:41 AM »
yes, however be warned
they must be installed exactly where they were down loaded  and will not allow one to copy the downloaded files to another machine or even save to a network location
« Reply #3 on: July 08, 2015, 12:03:42 PM »
I've had better luck not using the 'download manager'.
« Reply #4 on: July 08, 2015, 12:39:34 PM »
If I recall there is that link one can follow; however I think it only appears after a few fails?
Or you have to search around too find the link to install without using the download mangler
« Reply #5 on: July 08, 2015, 04:22:35 PM »
... "8 errors" and stops working. *shrug* ...
Parallels the behaviour of the installed version. #fail
huiz
  • Certified Prof C3D
« Reply #6 on: July 09, 2015, 05:59:02 AM »
Can't you access the download via accounts.autodesk.com? Here you can make a choise. I'm not sure if 2016 is in the list if you don't have a license.
« Reply #7 on: July 09, 2015, 07:09:24 AM »
Nope! I see nothing about downloading.
