Author Topic: setvar "CPLOTSTYLE" to existing plotstyle  (Read 3449 times)
Peter2
« on: May 27, 2015, 03:39:37 PM »
I have named plotstyles and want to use
  1. (setvar "CPLOTSTYLE" "test")
Of course I get an error if the named plotstyle "test" does not exist.
How can I check if "test" exists?
Peter
BricsCAD V23
Re: setvar "CPLOTSTYLE" to existing plotstyle
« Reply #1 on: May 27, 2015, 03:54:48 PM »
Perhaps:
  1. (defun _plotstylexist-p (stylename / d)
  2.   (and (setq d (dictsearch (namedobjdict) "ACAD_PLOTSTYLENAME"))
  3.        (dictsearch (cdr (assoc -1 d)) stylename)
  4.   )
  5. )
  6. (_plotstylexist-p "normal")
BlackBox
« Reply #2 on: May 27, 2015, 03:59:16 PM »
You can use something like this:
  1. (defun c:FOO (/ _GetPlotSettings acDoc)
  2.
  3.   (defun _GetPlotSettings (doc / plotSettings)
  4.                           "ACAD_PLOTSETTINGS"
  5.                 )
  6.       (setq plotSettings (cons (vla-get-name x) plotSettings))
  7.     )
  8.     (reverse plotSettings)
  9.   )
  10.
  11.   (if
  12.     (and
  13.       (vl-position "Test" (_GetPlotSettings acDoc))
  14.     )
  15.      (setvar 'cplotstyle "Test")
  16.      (prompt "\n** \"Test\" is not an available plot style ** ")
  17.   )
  18.   (princ)
  19. )
  20.
[Edit] - D@mn ninjas
Peter2
« Reply #3 on: May 27, 2015, 04:00:22 PM »
Thanks ronjonp
in the meantime I found a post by irneb (thanks too !  :-))
http://forums.augi.com/archive/index.php/t-102823.html
  1. (setq ed (entget (cdr (cadr (member '(3 . "ACAD_PLOTSTYLENAME") root)))))
  2. (member (cons 3 "test") ed)
Peter
BricsCAD V23
« Reply #4 on: May 27, 2015, 04:03:57 PM »
Thanks ronjonp
in the meantime I found a post by irneb (thanks too !  :) )
Glad you found what you needed. Be aware that using member to look for an item in a list is case sensitive.
  1. (member (cons 3 "Test")(list (cons 3 "test")))
  2. nil
« Reply #5 on: May 27, 2015, 04:04:27 PM »
Peter2
« Reply #6 on: May 27, 2015, 04:17:00 PM »
Hi
thanks to all.
@ronjonp: works fine, short, easy, not case-sensitive, .. - perfect.
@BlackBox: I tried, but "_GetPlotSettings" returns always nil ..
@irneb (from 2009): works too, but with case-sensitivity.
Thanks for that great forum!
Peter
BricsCAD V23
Peter2
« Reply #7 on: May 27, 2015, 05:08:46 PM »
Additional info for special cases:
  1. ...(dictsearch (namedobjdict) "ACAD_PLOTSTYLENAME"))...
The dictionary is not refreshed when the STB is changed. Usually this happens not very often, but ..
- I had "a.stb" with plotstyle "test": Everything OK.
- I replaced it with "b.stb" without "test": The code says "test exists", while (setvar "cplotstyle" "test") reports an error "test does not exists".
Peter
BricsCAD V23
roy_043
  • BricsCAD 18
« Reply #8 on: May 27, 2015, 05:52:43 PM »
Actually the "ACAD_PLOTSTYLENAME" dictionary does not list the styles in the STB file. It lists the styles that are in use in the drawing.
roy_043
  • BricsCAD 18
« Reply #9 on: May 28, 2015, 04:04:45 AM »
Try using:
(vl-catch-all-apply 'setvar '(cplotstyle "test"))
Peter2
« Reply #10 on: May 28, 2015, 09:26:01 AM »
Yes, you're right. Searching the "available" plotstyles needs another solution.
Try using:
Yes, it works. Namely there is still an error-message created by Autocad (not Lisp), but the lisp continues to work.
Peter
BricsCAD V23
« Reply #11 on: May 28, 2015, 10:09:00 AM »
Try using:
Maybe this ?
  1. (vl-directory-files (getenv "PrinterStyleSheetDir") "*.*tb" 1)
Peter2
« Reply #12 on: May 28, 2015, 10:25:05 AM »
Returns nil. I suppose this should return the existing files, but for this I have another solution.
But the analysis of the STB leads too far from my basic target; I'm happy with the solution above. Thanks a lot for your help!
Peter
BricsCAD V23
