Author Topic: PDF  (Read 26062 times)
Re: PDF
« Reply #45 on: May 06, 2015, 02:27:15 PM »
actually the plot offset number should be zeros....
IF you have set your title block/border and inked area limits correctly.
Exactly .. me thinks this is not the case. The example you provided does not either if you 'Apply to Layout'.
it works here...
Re: PDF
« Reply #46 on: May 06, 2015, 02:37:07 PM »
Cannot set your pagesetup to current .. does not like it because it's missing a defined ctb.
Re: PDF
« Reply #47 on: May 06, 2015, 02:47:28 PM »
interesting it is using the NONE ctb...???
here it is with the bone stock acad.ctb
Bethrine
Re: PDF
« Reply #48 on: May 06, 2015, 02:47:42 PM »
Okay, I remember setting paper size and printable area but that was a long time ago. I am perfectly capable of math. Suddenly it makes more sense...if I set margins to .5 all around and Plot Offset to 0,0 it will / should show if my printable area is sized and / or located properly. Is that correct?
Re: PDF
« Reply #49 on: May 06, 2015, 02:48:53 PM »
yes
Re: PDF
« Reply #50 on: May 06, 2015, 02:52:10 PM »
interesting it is using the NONE ctb... :?
This is what I see when I open your first example (assuming you had already set the setup to current).
Bethrine
Re: PDF
« Reply #51 on: May 06, 2015, 02:55:46 PM »
That is a 1" x 1" square through a 1 : 1 viewport.
Printing...
Bethrine
Re: PDF
« Reply #52 on: May 06, 2015, 02:58:34 PM »
The border is not where I want it but my square comes out at less then 1/32" short of an inch in both x and y directions.
Bethrine
Re: PDF
« Reply #53 on: May 06, 2015, 03:01:24 PM »
Lunch break be back in 30. Feel free to discuss.
Re: PDF
« Reply #54 on: May 06, 2015, 03:17:47 PM »
b sure the pdf is NOT scaling or FIT-ting  must chose ACTUAL SIZE
some were not doing that correctly here and were complaining about drawings being scaled when plotted
Re: PDF
« Reply #55 on: May 06, 2015, 03:19:39 PM »
see here   http://www.theswamp.org/index.php?topic=49403.msg545130#msg545130
no offsets in my page setup
Re: PDF
« Reply #56 on: May 06, 2015, 03:23:27 PM »
FWIW .. here's how our titleblock is constructed. It has a border the size of the paper that does not plot so the titleblock always has equal bottom, top & right margins then the left margin is a little bigger for binding. It's inserted\xref on each tab @ 0,0 and plotted by layout or extents ... either works.
« Last Edit: May 06, 2015, 04:11:27 PM by ronjonp »
Re: PDF
« Reply #57 on: May 06, 2015, 03:25:10 PM »
Yup .. saw that. Your page size is not 11x17 either (name of the setup).
Re: PDF
« Reply #58 on: May 06, 2015, 03:33:16 PM »
noted and fixed that @ 2nd posting of the file (Sample.dwg)
The point being the process works as described.
Bethrine
Re: PDF
« Reply #59 on: May 06, 2015, 03:34:42 PM »
How do I get to that window?
