Author Topic: Need help with attribute change routine  (Read 2031 times)
TJAM51
« on: April 26, 2005, 12:28:25 PM »
If I have attributes on certain layers how can I put in a small lisp routine the ability to change all these attributes to a different color based upon what layer the are defined on. The attributes I speak of are on specific layers and would like a routine that would identify these and change them to a color that is defined within the routine.
  • Custom Title
« Reply #1 on: April 27, 2005, 08:50:06 AM »
Ive tried a few things, so far nothing works.
nivuahc
Re: Need help with attribute change routine
« Reply #2 on: April 27, 2005, 09:03:24 AM »
Quote from: TJAM51
As opposed to BYLAYER or BYLBLOCK?
I'm not quite sure I follow...
nivuahc
« Reply #3 on: April 27, 2005, 09:17:52 AM »
I found this, a while back, but I have no idea who wrote it. Perhaps you can modify it to do what you want:
;   File Name: FIXBLOCK.LSP
;   Description: Puts all of a blocks sub-entities on layer 0 with color
; linetype set to BYBLOCK. The block, itself, will remain on
; its' original layer.
(defun d_FixBlock (/ eBlockSel ; Block selection
  lInsertData ; Entity data
  sBlockName ; Block name
  lBlockData ; Entity data
  eSubEntity ; Sub-entity name
  lSubData ; Sub-entity data
  iCount ; Counter
  ;; Redefine error handler
  (setq
    d_#error *error*
    *error*  d_FB_Error
  ) ;_ end setq
  ;; Set up environment
  (setq #SYSVARS (#SaveSysVars (list "cmdecho")))
  (setvar "cmdecho" 0)
  (command "._undo" "_group")
  ;; Get block from user and make sure it's an INSERT type
  (if (setq eBlockSel (entsel "\nSelect block to change :"))
      (if (setq lInsertData (entget (car eBlockSel)))
(if (= (cdr (assoc 0 lInsertData)) "INSERT")
 (setq sBlockName (cdr (assoc 2 lInsertData)))
   (alert "Entity selected is not a block!")
   (exit)
 ) ;_ end progn
) ;_ end if
 (alert "Invalid Block Selection!")
 (exit)
) ;_ end progn
      ) ;_ end if
      ;; Get block info from the block table
      (setq
lBlockData (tblsearch "BLOCK" sBlockName)
eSubEntity (cdr (assoc -2 lBlockData))
      ) ;_ end setq
      ;; Make sure block is not an Xref
      (if (not (assoc 1 lBlockData))
 (princ "\nProcessing block: ")
 (princ sBlockName)
 (princ "\nUpdating blocks sub-entities. . .")
 ;; Parse through all of the blocks sub-entities
 (while eSubEntity
   (princ " .")
   (setq lSubData (entget eSubEntity))
   ;; Update layer property
   (if (assoc 8 lSubData)
(setq lSubData
      (subst
(cons 8 "0")
(assoc 8 lSubData)
lSubData
      ) ;_ end subst
) ;_ end setq
(entmod lSubData)
     ) ;_ end progn
   ) ;_ end if
   ;; Update the linetype property
   (if (assoc 6 lSubData)
(setq lSubData
      (subst
(cons 6 "BYBLOCK")
(assoc 6 lSubData)
lSubData
      ) ;_ end subst
) ;_ end setq
(entmod lSubData)
     ) ;_ end progn
     (entmod (append lSubData (list (cons 6 "BYBLOCK"))))
   ) ;_ end if
   ;; Update the color property
   (if (assoc 62 lSubData)
(setq lSubData
      (subst
(cons 62 0)
(assoc 62 lSubData)
lSubData
      ) ;_ end subst
) ;_ end setq
(entmod lSubData)
     ) ;_ end progn
     (entmod (append lSubData (list (cons 62 0))))
   ) ;_ end if
   (setq eSubEntity (entnext eSubEntity))
; get next sub entity
 ) ; end while
 ;; Update attributes
 (idc_FB_UpdAttribs)
) ; end progn
(alert "XREF selected. Not updated!")
      ) ; end if
    ) ; end progn
    (alert "Nothing selected.")
  ) ; end if
;;; Pop error stack and reset environment
  (idc_RestoreSysVars)
  (princ "\nDone!")
  (setq *error* d_#error)
); end defun
; Function to update block attributes
(defun idc_FB_UpdAttribs ()
  ;; Update any attribute definitions
  (setq iCount 0)
  (princ "\nUpdating attributes. . .")
  (if (setq ssInserts (ssget "x"
    (list (cons 0 "INSERT")
  (cons 66 1)
  (cons 2 sBlockName)
    ) ;_ end list
     ) ;_ end ssget
      ) ;_ end setq
    (repeat (sslength ssInserts)
      (setq eBlockName (ssname ssInserts iCount))
      (if (setq eSubEntity (entnext eBlockName))
(setq
 eSubType (cdr (assoc 0 lSubData))
) ;_ end setq
      ) ;_ end if
      (while (or (= eSubType "ATTRIB") (= eSubType "SEQEND"))
   (setq lSubData
  (subst
    (cons 8 "0")
    (assoc 8 lSubData)
    lSubData
  ) ;_ end subst
   ) ;_ end setq
   (entmod lSubData)
 ) ;_ end progn
) ;_ end if
   (setq lSubData
  (subst
    (cons 6 "BYBLOCK")
    (assoc 6 lSubData)
    lSubData
  ) ;_ end subst
   ) ;_ end setq
   (entmod lSubData)
 ) ;_ end progn
) ;_ end if
   (setq lSubData
  (subst
    (cons 62 0)
    (assoc 62 lSubData)
    lSubData
  ) ;_ end subst
   ) ;_ end setq
   (entmod lSubData)
 ) ;_ end progn
) ;_ end if
(if (setq eSubEntity (entnext eSubEntity))
 (setq
 ) ;_ end setq
 (setq eSubType nil)
) ;_ end if
      ) ; end while
      (setq iCount (1+ iCount))
    ) ; end repeat
  ) ; end if
  (command "regen")
) ; end defun
; Function to save a list of system variables
(defun #SaveSysVars (lVarList / sSystemVar)
  (mapcar
    '(lambda (sSystemVar)
       (setq lSystemVars
     (append lSystemVars
     (list (list sSystemVar (getvar sSystemVar)))
     ) ;_ end append
       ) ;_ end setq
     ) ;_ end lambda
    lVarList
  ) ;_ end mapcar
  lSystemVars
) ;_ end defun
; Function to restore a list of system variables
(defun idc_RestoreSysVars ()
  (mapcar
       (setvar (car sSystemVar) (cadr sSystemVar))
     ) ;_ end lambda
    #SYSVARS
  ) ;_ end mapcar
) ;_ end defun
; Error Handler
(defun d_FB_Error (msg)
  (princ "\nError occurred in the Fix Block routine...")
  (princ "\nError: ")
  (princ msg)
  (if *error*
    (*error* msg)
  ) ;_ end if
  (command)
  (if (/= msg "quit / exit abort")
      (command "._undo" "_end")
      (command "._u")
    ) ;_ end progn
  ) ;_ end if
) ;_ end defun
(defun c:FB () (d_FixBlock))
;;;(fb)
CADaver
« Reply #4 on: April 27, 2005, 12:47:29 PM »
Quote from: TJAM51
Redefine the block to place that attribute on layer 0, color and linetype bylayer (run ATTSYNC).  Then it's a simple function to just change it's layer.
