I found this, a while back, but I have no idea who wrote it. Perhaps you can modify it to do what you want:
; File Name: FIXBLOCK.LSP
; Description: Puts all of a blocks sub-entities on layer 0 with color
; linetype set to BYBLOCK. The block, itself, will remain on
; its' original layer.
(defun d_FixBlock (/ eBlockSel ; Block selection
lInsertData ; Entity data
sBlockName ; Block name
lBlockData ; Entity data
eSubEntity ; Sub-entity name
lSubData ; Sub-entity data
iCount ; Counter
;; Redefine error handler
(setq
d_#error *error*
*error* d_FB_Error
) ;_ end setq
;; Set up environment
(setq #SYSVARS (#SaveSysVars (list "cmdecho")))
(setvar "cmdecho" 0)
(command "._undo" "_group")
;; Get block from user and make sure it's an INSERT type
(if (setq eBlockSel (entsel "\nSelect block to change :"))
(if (setq lInsertData (entget (car eBlockSel)))
(if (= (cdr (assoc 0 lInsertData)) "INSERT")
(setq sBlockName (cdr (assoc 2 lInsertData)))
(alert "Entity selected is not a block!")
(exit)
) ;_ end progn
) ;_ end if
(alert "Invalid Block Selection!")
(exit)
) ;_ end progn
) ;_ end if
;; Get block info from the block table
(setq
lBlockData (tblsearch "BLOCK" sBlockName)
eSubEntity (cdr (assoc -2 lBlockData))
) ;_ end setq
;; Make sure block is not an Xref
(if (not (assoc 1 lBlockData))
(princ "\nProcessing block: ")
(princ sBlockName)
(princ "\nUpdating blocks sub-entities. . .")
;; Parse through all of the blocks sub-entities
(while eSubEntity
(princ " .")
(setq lSubData (entget eSubEntity))
;; Update layer property
(if (assoc 8 lSubData)
(setq lSubData
(subst
(cons 8 "0")
(assoc 8 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
) ;_ end if
;; Update the linetype property
(if (assoc 6 lSubData)
(setq lSubData
(subst
(cons 6 "BYBLOCK")
(assoc 6 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
(entmod (append lSubData (list (cons 6 "BYBLOCK"))))
) ;_ end if
;; Update the color property
(if (assoc 62 lSubData)
(setq lSubData
(subst
(cons 62 0)
(assoc 62 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
(entmod (append lSubData (list (cons 62 0))))
) ;_ end if
(setq eSubEntity (entnext eSubEntity))
; get next sub entity
) ; end while
;; Update attributes
(idc_FB_UpdAttribs)
) ; end progn
(alert "XREF selected. Not updated!")
) ; end if
) ; end progn
(alert "Nothing selected.")
) ; end if
;;; Pop error stack and reset environment
(idc_RestoreSysVars)
(princ "\nDone!")
(setq *error* d_#error)
); end defun
; Function to update block attributes
(defun idc_FB_UpdAttribs ()
;; Update any attribute definitions
(setq iCount 0)
(princ "\nUpdating attributes. . .")
(if (setq ssInserts (ssget "x"
(list (cons 0 "INSERT")
(cons 66 1)
(cons 2 sBlockName)
) ;_ end list
) ;_ end ssget
) ;_ end setq
(repeat (sslength ssInserts)
(setq eBlockName (ssname ssInserts iCount))
(if (setq eSubEntity (entnext eBlockName))
(setq
eSubType (cdr (assoc 0 lSubData))
) ;_ end setq
) ;_ end if
(while (or (= eSubType "ATTRIB") (= eSubType "SEQEND"))
(setq lSubData
(subst
(cons 8 "0")
(assoc 8 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
) ;_ end if
(setq lSubData
(subst
(cons 6 "BYBLOCK")
(assoc 6 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
) ;_ end if
(setq lSubData
(subst
(cons 62 0)
(assoc 62 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
) ;_ end if
(if (setq eSubEntity (entnext eSubEntity))
(setq
) ;_ end setq
(setq eSubType nil)
) ;_ end if
) ; end while
(setq iCount (1+ iCount))
) ; end repeat
) ; end if
(command "regen")
) ; end defun
; Function to save a list of system variables
(defun #SaveSysVars (lVarList / sSystemVar)
(mapcar
'(lambda (sSystemVar)
(setq lSystemVars
(append lSystemVars
(list (list sSystemVar (getvar sSystemVar)))
) ;_ end append
) ;_ end setq
) ;_ end lambda
lVarList
) ;_ end mapcar
lSystemVars
) ;_ end defun
; Function to restore a list of system variables
(defun idc_RestoreSysVars ()
(mapcar
(setvar (car sSystemVar) (cadr sSystemVar))
) ;_ end lambda
#SYSVARS
) ;_ end mapcar
) ;_ end defun
; Error Handler
(defun d_FB_Error (msg)
(princ "\nError occurred in the Fix Block routine...")
(princ "\nError: ")
(princ msg)
(if *error*
(*error* msg)
) ;_ end if
(command)
(if (/= msg "quit / exit abort")
(command "._undo" "_end")
(command "._u")
) ;_ end progn
) ;_ end if
) ;_ end defun
(defun c:FB () (d_FixBlock))
;;;(fb)
