Author Topic: civil deed map closure routine  (Read 1195 times)
Cadbox10
« on: February 10, 2015, 01:11:33 PM »
Dear Sir or Mrs.,
where I work, we are using basic autocad release 12.
I work for a small civil engineering company and I use
lisp routines to help with drafting work.
I was hoping that maybe you would have or know where I
could find a deed traverse closure routine that would
be able to print out a closure sheet with any error check
where the property did not close.
If you have this please send me an attachment.
Thank you much
Rob...
Re: civil deed map closure routine
« Reply #1 on: February 10, 2015, 01:20:44 PM »
Are you sure you mean release 12 and not 2012?
Release 12 came out in 1992.
CAD Tech
Cadbox10
« Reply #2 on: February 10, 2015, 11:16:18 PM »
yes . . . I am using 2012  :-D
any luck locating a routine?
Rob...
« Reply #3 on: February 11, 2015, 07:22:47 AM »
I don't do Civil. I just wanted to make sure the version was correct, or not. Maybe someone else will be able to help.
CAD Tech
