Author Topic: Text Lisp Help needed  (Read 7705 times)
David Hall
  • Automatic Duh Generator
« Reply #15 on: April 22, 2005, 09:47:59 AM »
I created this if you need it
One Shot
« Reply #16 on: April 22, 2005, 09:49:01 AM »
Quote from: CmdrDuh
So now you have the 2005doc back, do you need to create an Acaddoc.lsp?
I did a save as of my presnet Acaddoc.lsp and named it Acaddoc1.lsp.  Please look at this Acaddoc1.lsp and tell if I did it correctly.  If not, please show me how to properly create one.
;;  ACADDOC1.LSP
;;  ACADDOC1.LSP  ver. 2005
;;  B.N. Crouse
;;  04/22/05
;;  FUNCTION Defuns
(load "fixtextstyle.lsp")
;; This then runs the c:fx function as you have it defined
;; in the fixtextstyle.lsp file
(c:fx)
David Hall
« Reply #17 on: April 22, 2005, 09:53:34 AM »
As far as i know, that will work.  I posted a version of acaddoc.lsp which defined FX and ran it.
Not that you need to do that, I was just trying to help.  What I do see is this:  In your existing acaddoc.lsp, you will need to (load "acaddoc1.lsp")
ANY GURUs watching this PLEASE correct me if im wrong here
One Shot
« Reply #18 on: April 22, 2005, 10:23:29 AM »
Quote from: CmdrDuh
CmdrDuh,
Thank you for your help.  It is working now.
Thank you,
Brad
David Hall
« Reply #19 on: April 22, 2005, 10:24:42 AM »
Glad its working
One Shot
« Reply #20 on: April 26, 2005, 06:54:58 PM »
I am running into a problem with this lisp.  What I am trying to is to have 2 Text styles changed from simplex.shx to swiss721 BT.  If you look at the lisp @ defun c:fx1.  This is where I would like to have it change.  Can some please point me in the right direction?
Thank you for all your help.
Date Modified: 04/22/05
By Whom: Bcrouse
(defun C:fx ( / stylist txtstyle ss indx ent ent_alst str)
  (setvar "cmdecho" 0)
  (command "_.undo" "be")
  (setq stylist '("NOTES" "DWGTITLES" "DWGTITLE" "HANDDWGTITLE" "HANDWGTITLES" "HANDWGTITLE" "RMNAMES"))
  (while (/= stylist nil)
    (setq txtstyle (car stylist))
    (if (= (tblsearch "STYLE" txtstyle) nil)
      (command "-style" txtstyle "simplex.shx" 0 0.7 0 "No" "No" "No")
      (fixtxtstyle txtstyle)
    (setq stylist (cdr stylist))
  (setq ss (ssget "X" '((0 . "TEXT,MTEXT")
                (7 . "NOTES,DWGTITLES,DWGTITLE,HANDWGTITLE,HANDDWGTITLEs,HANDWGTITLEs,RMNAMES"))))
  (setq indx 0)
  (if (/= ss nil)
    (while (<= indx (- (sslength ss) 1))
      (setq ent (ssname ss indx))
      (setq ent_alst (entget ent))
        ((= (cdr (assoc 0 ent_alst)) "TEXT")
          (setq ent_alst (subst (cons 41 0.7) (assoc 41 ent_alst) ent_alst))
        ((= (cdr (assoc 0 ent_alst)) "MTEXT")
          (setq str (cdr (assoc 1 ent_alst)))
          (if (/= (vl-string-position (ascii ";") str) nil)
              (setq str (strcat "{" (substr str (+ (vl-string-position (ascii ";") str) 2))))
              (setq ent_alst (subst (cons 1 str) (assoc 1 ent_alst) ent_alst))
      (entmod ent_alst)
      (entupd ent)
      (setq indx (1+ indx))
  (command "_.regen")
  (command "_.undo" "end")
  (setvar "textstyle" "NOTES")
  (setvar "cmdecho" 1)
(defun fixtxtstyle (txtsty / txtsty)
  (setq txtsty (entget (tblobjname "STYLE" txtsty)))
  (setq txtsty (subst (cons 41 0.7) (assoc 41 txtsty) txtsty))
  (setq txtsty (subst (cons 3 "simplex.shx") (assoc 3 txtsty) txtsty))
  (entmod txtsty)
(defun C:fx1 ( / stylist txtstyle ss indx ent ent_alst str)
  (setq stylist '("DWGTITLES" "RMNAMES"))
      (command "-style" txtstyle "Swis721 BT.shx" 0 0.7 0 "No" "No" "No")
                (7 . "DWGTITLES,RMNAMES"))))
  (setq indx 0)
  (if (/= ss nil)
      (entmod ent_alst)
      (entupd ent)
  (command "_.regen")
  (setvar "textstyle" "DWGTITLES")
  (setq txtsty (subst (cons 3 "Swis721 BT.shx") (assoc 3 txtsty) txtsty))
  (entmod txtsty)
« Reply #21 on: April 26, 2005, 07:34:45 PM »
Try This.
;;; Date Modified: 04/22/05
;;; By Whom: Bcrouse
(defun C:fx ( / stylist txtstyle ss indx ent ent_alst str fixtxtstyle)
  (defun fixtxtstyle (txtsty)
    (entmod txtsty)
  (setq indx 0)
  (if (/= ss nil)
      (entmod ent_alst)
      (entupd ent)
  (command "_.regen")
(defun C:fx1 ( / stylist txtstyle ss indx ent ent_alst str fixtxtstyle)
  (defun fixtxtstyle (txtsty )
    (entmod txtsty)
  (setq indx 0)
  (if (/= ss nil)
      (entmod ent_alst)
      (entupd ent)
  (command "_.regen")
One Shot
« Reply #22 on: April 27, 2005, 11:52:21 AM »
I need to add the Text Style before I do a text style merge.  I would like to add this to the lisp that is associated with this thread.  How would I go about doing this.  I know that I need to ensure that the font sylte is found.  But I don't know how to do that.  Can someone please point me in the right direct?
(command "-style" "DWGTITLES"  "swis721 BT.shx" 1.20 0 "No" "No" "No")
