If bylayer you mean they do not inherit the color of the layer they are on...try this:http://www.theswamp.org/phpBB2/viewtopic.php?p=47069#47069Ron
;****************************************************************************************; UPDATE BLOCK COLOR (updblkcl.lsp); PRE-INSERTED BLOCK DEFINITION CLEAN-UP UTILITY;; This routine is especially usefull to redefine pre-inserted blocks whose; entity colors need to be changed to BYLAYER.;; This routine allows the user to update the color of; all entities within a block to a single color (exam: color=BYLAYER); without the user having to explode the symbol. By default the layer name of; all entities are NOT changed. The routine changes the original; definition of the block within the current drawing.; ; To use this routine the user is asked to specify a single; color to place all entities of a selected block(s).;; The user is next prompted to select one or more blocks to update. The routine; then redefines all entities of the block to the color specified.;; When the user regenerates the drawing she/he will find that all; occurances of the block have been redefined. This is because the; original definition of the block is changed!!!;; by CAREN LINDSEY, July 1996;****************************************************************************************;;INTERNAL ERROR HANDLER(defun err-ubc (s) ; If an error (such as CTRL-C) occurs ; while this command is active... (if (/= s "Function cancelled") (princ (strcat "\nError: " s)) ) (setq *error* olderr) ; Restore old *error* handler (princ));err-ubc(DEFUN C:BBL (/ BLK CBL CBL2 C ACL ALY NLY NCL) (setq olderr *error* *error* err-ubc) (initget "?") (while (or (eq (setq C (getint "\nEnter new color number/<?>: ")) "?") (null C) (> C 256) (< C 0) );or (textscr) (princ "\n ") (princ "\n Color number | Standard meaning ") (princ "\n ________________|____________________") (princ "\n | ") (princ "\n 0 | <BYBLOCK> ") (princ "\n 1 | Red ") (princ "\n 2 | Yellow ") (princ "\n 3 | Green ") (princ "\n 4 | Cyan ") (princ "\n 5 | Blue ") (princ "\n 6 | Magenta ") (princ "\n 7 | White ") (princ "\n 8...255 | -Varies- ") (princ "\n 256 | <BYLAYER> ") (princ "\n \n\n\n") (initget "?") );while (PROMPT "\nPick blocks to update. ") (SETQ SS (SSGET '((0 . "INSERT")))) (SETQ K 0) (WHILE (< K (SSLENGTH SS)) (setq CBL (tblsearch "BLOCK" (CDR (ASSOC 2 (ENTGET (SETQ BLK (SSNAME SS K))))))) (SETQ CBL2 (CDR (ASSOC -2 CBL))) (WHILE (BOUNDP 'CBL2) (SETQ EE (ENTGET CBL2)) ;Update layer value (SETQ NCL (CONS 62 C)) (SETQ ACL (ASSOC 62 EE)) (IF (= ACL nil) (SETQ NEWE (APPEND EE (LIST NCL))) (SETQ NEWE (SUBST NCL ACL EE)) );if (ENTMOD NEWE) (SETQ CBL2 (ENTNEXT CBL2)) );end while (ENTUPD BLK) (SETQ K (1+ K)) );end while (setq *error* olderr) (princ));end updblkcl
