i am trying to use this lisp to break and hide lines. when we do reflected details we hide part of our mounting bracket under a fascia. the bracket is a block and the fascia varies in size. it has two main problems. first it doesn't work on blocks and second when i hide the line which is the leg of the angle it goes to the corner insted of remaining straight. this block will be a dynamic block project in the future but until then i need an affective break and hide lisp. can anybody help me out please. here what i have:
;;CADALYST 01/04 Tip1919: BKH.LSP Break and Hide (c) 2004 J.D. Henman
;;; 20031002 JDH BKH.LSP
;;; For breakout of arcs & lines and inserting hidden replacement
(defun c:HDN (/ oclayer)
(setq oclayer (getvar "clayer"))
(command "layer" "m" "HIDDEN" "c" "9" "" "lt" "hidden" "" "")
(setvar "clayer" oclayer)
) ;defun
(defun c:BKH (/ oclayer olsnap bobj bobj2 bobytyp pt1 pt2 pt3 bobjcen rdist)
(C:hdn)
(setq olsnap (getvar "osmode"))
(setvar "osmode" 127)
(setq bobj (entsel "\n Select Line, Polyline, Circle or Arc to Break: "))
(setq bobj2 (assoc 0 (entget (car bobj))))
(setq bobjtyp (cdr bobj2))
(if ( or (= bobjtyp "LINE")(= bobjtyp "LWPOLYLINE") (= bobjtyp "POLYLINE"))
(setq pt2 (getpoint "\nSelect First Intersection. "))
(setq pt3 (getpoint "\nSelect Second Intersection. "))
(command "break" bobj "_f" pt2 pt3)
(setvar "clayer" "HIDDEN")
(command "line" pt2 pt3 "")
(setvar "osmode" olsnap)
) ;progn
(if (or (= bobjtyp "CIRCLE") (= bobjtyp "ARC"))
(princ "\nsee here")
(setq bobjcen (assoc 10 (entget (car bobj))))
(setq pt1 (cdr bobjcen))
(setq rdist (distance pt1 pt2))
;(setvar "osmode" 127)
(command "arc" "C" pt1 pt2 pt3)
) ;progn
(princ "\n Arc, Circle, Polyline or Line not selected")
) ;if
) ;if
) ;defun
