Author Topic: C++ to lisp  (Read 9701 times)
Re: C++ to lisp
« Reply #15 on: December 08, 2014, 04:45:38 AM »
pedroantonio124,
Which AutoCAD build are you using ?
pedroantonio124
Re: C++ to lisp
« Reply #16 on: December 08, 2014, 04:54:23 AM »
AutoCad 2014
irneb
Re: C++ to lisp
« Reply #17 on: December 08, 2014, 05:30:16 AM »
Hello irneb,
Thanks for your help  :-)
Unfortunately, I still receive the wrong result with the lisp code.
Maybe I can find the mistake if I know the result of every line.
Could you let me the C # run through over again code? Please
With a Console.WriteLine for every line.
Rather than a WriteLine per line ... just get hold of a DotNet IDE and debug step through it.
You can get a free IDE, either of these would do:
Re: C++ to lisp
« Reply #18 on: December 08, 2014, 05:36:07 AM »
You want fries with this ?
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Globalization;
  4. using System.Linq;
  5. using System.Text;
  6. using System.Threading.Tasks;
  7.
  8. namespace ToLatLon
  9. {
  10.     internal class Program
  11.     {
  12.         private static void Main(string[] args)
  13.         {
  14.             Console.Write("\n UTM to LatLon test.\n From theSwamp\n http://www.theswamp.org/index.php?topic=48330.0" );
  15.             Console.Write("\n\nEnter utmX value : " );
  16.             double utmX = double.Parse(Console.ReadLine());
  17.
  18.             Console.Write("\nEnter utmY value : " );
  19.             double utmY = double.Parse(Console.ReadLine());
  20.
  21.             Console.Write("\nEnterutmZone value : " );
  22.             string utmZone = Console.ReadLine();
  23.
  24.             ToLatLon(utmX, utmY, utmZone);
  25.
  26.             Console.ReadKey();
  27.         }
  28.
  29.         public static void ToLatLon(double utmX, double utmY, string utmZone)
  30.         {
  31.             double latitude = 0;
  32.             double longitude = 0;
  33.
  34.             bool isNorthHemisphere = utmZone.Last() >= 'N';
  35.
  36.             var diflat = -0.00066286966871111111111111111111111111;
  37.             var diflon = -0.0003868060578;
  38.
  39.             var zone = int.Parse(utmZone.Remove(utmZone.Length - 1));
  40.             var c_sa = 6378137.000000;
  41.             var c_sb = 6356752.314245;
  42.
  43.             var e2 = Math.Pow((Math.Pow(c_sa, 2) - Math.Pow(c_sb, 2)), 0.5)/c_sb;
  44.             Console.WriteLine("\ne2:\t " + e2.ToString());
  45.
  46.             var e2cuadrada = Math.Pow(e2, 2);
  47.             Console.WriteLine("\ne2cuadrada:\t " + e2cuadrada.ToString());
  48.
  49.             var c = Math.Pow(c_sa, 2)/c_sb;
  50.             Console.WriteLine("\nc:\t " + c.ToString());
  51.
  52.             var x = utmX - 500000;
  53.             Console.WriteLine("\nx:\t " + x.ToString());
  54.
  55.             var y = isNorthHemisphere ? utmY : utmY - 10000000;
  56.             Console.WriteLine("\ny:\t " + y.ToString());
  57.
  58.             var s = ((zone*6.0) - 183.0);
  59.             Console.WriteLine("\ns:\t " + s.ToString());
  60.
  61.             var lat = y/(6366197.724*0.9996); // Change c_sa for 6366197.724
  62.             Console.WriteLine("\nlat:\t " + lat.ToString());
  63.
  64.             var v = (c/
  65.                      Math.Pow(1 + (e2cuadrada*Math.Pow(Math.Cos(lat), 2)), 0.5))*
  66.                     0.9996;
  67.             Console.WriteLine("\nv:\t " + v.ToString());
  68.
  69.             var a = x/v;
  70.             Console.WriteLine("\na:\t " + a.ToString());
  71.
  72.             var a1 = Math.Sin(2*lat);
  73.             Console.WriteLine("\na1:\t " + a1.ToString());
  74.
  75.             var a2 = a1*Math.Pow((Math.Cos(lat)), 2);
  76.             Console.WriteLine("\na2:\t " + a2.ToString());
  77.
  78.             var j2 = lat + (a1/2.0);
  79.             Console.WriteLine("\nj2:\t " + j2.ToString());
  80.
  81.             var j4 = ((3*j2) + a2)/4.0;
  82.             Console.WriteLine("\nj4:\t" + j4.ToString());
  83.
  84.             var j6 = (5*j4 + a2*Math.Pow((Math.Cos(lat)), 2))/3.0;
  85.             // saque a2 de multiplicar por el coseno de lat y elevar al cuadrado
  86.             Console.WriteLine("\nj6:\t " + j6.ToString());
  87.
  88.             var alfa = (3.0/4.0)*e2cuadrada;
  89.             Console.WriteLine("\nalfa:\t " + alfa.ToString());
  90.
  91.             var beta = (5.0/3.0)*Math.Pow(alfa, 2);
  92.             Console.WriteLine("\nbeta:\t " + beta.ToString());
  93.
  94.             var gama = (35.0/27.0)*Math.Pow(alfa, 3);
  95.             Console.WriteLine("\ngama:\t " + gama.ToString());
  96.
  97.             var bm = 0.9996*c*(lat - alfa*j2 + beta*j4 - gama*j6);
  98.             Console.WriteLine("\nbm:\t " + bm.ToString());
  99.
  100.             var b = (y - bm)/v;
  101.             Console.WriteLine("\nb:\t " + b.ToString());
  102.
  103.             var epsi = ((e2cuadrada*Math.Pow(a, 2))/2.0)*
  104.                        Math.Pow((Math.Cos(lat)), 2);
  105.             Console.WriteLine("\nepsi:\t " + epsi.ToString());
  106.
  107.             var eps = a*(1 - (epsi/3.0));
  108.             Console.WriteLine("\neps:\t " + eps.ToString());
  109.
  110.             var nab = (b*(1 - epsi)) + lat;
  111.             Console.WriteLine("\nnab:\t " + nab.ToString());
  112.
  113.             var senoheps = (Math.Exp(eps) - Math.Exp(-eps))/2.0;
  114.             Console.WriteLine("\nsenoheps:\t " + senoheps.ToString());
  115.
  116.             var delt = Math.Atan(senoheps/(Math.Cos(nab)));
  117.             Console.WriteLine("\ndelt:\t " + delt.ToString());
  118.
  119.             var tao = Math.Atan(Math.Cos(delt)*Math.Tan(nab));
  120.             Console.WriteLine("\ntao:\t " + tao.ToString());
  121.
  122.             longitude = (delt/Math.PI)*180 + s;
  123.             latitude = (((lat +
  124.                           (1 + e2cuadrada*Math.Pow(Math.Cos(lat), 2) -
  125.                            (3.0/2.0)*e2cuadrada*Math.Sin(lat)*Math.Cos(lat)*
  126.                            (tao - lat))*(tao - lat)))/Math.PI)*180;
  127.             // era incorrecto el calculo
  128.
  129.             Console.WriteLine("\nLatitud:\t " + latitude.ToString() +
  130.                 "\nLongitud:\t " + longitude.ToString());
  131.         }
  132.     }
  133. }
  134.
irneb
Re: C++ to lisp
« Reply #19 on: December 08, 2014, 06:05:44 AM »
Damn ... you're much to quick!
Anyhow, if you don't want to install anything new, you could use IDEone: http://ideone.com/5irS8R
pedroantonio124
Re: C++ to lisp
« Reply #20 on: December 08, 2014, 06:06:25 AM »
Thanks  :-D
This was the mistake in the Lisp code
It now works  :lol: :-P ^-^ :laugh: :blank:
Incorrect: (setq eps (* a (1-  (/ epsi 3.0)))))
OK: (setq eps (* a (- 1 (/ epsi 3.0)))))
pedroantonio124
Re: C++ to lisp
« Reply #21 on: December 08, 2014, 10:45:05 AM »
Thanks to irneb and Kerry  :-)
example:
(utm2latlong 451602.19 4519076.99 "33N")
->40.821287°  14.426080°
PedroAntonio  :evil: :-P
(defun utm2latlong (utmX utmY utmZone / latitude longitude isNorthHemisphere diflat diflon zone c_sa
c_sb e2 e2cuadrada c x y s lat v a a1 a2 j2 j4 j6 alfa beta gama bm b
epsi eps nab senoheps delta tao longitude latitude)
(defun tan (x / c)
(if (= (setq c (cos x)) 0.0)
(* (if (< x 0) -1 1) 1.7976931348623158e+308) ;Closest we can get to infinity using a double floating point
(/ (sin x) c)
(setq LATLONG nil)
(setq isNorthHemisphere (wcmatch utmZone "*[Nn]"))
(setq diflat -0.00066286966871111111111111111111111111)
(setq diflon -0.0003868060578)
(setq zone (atoi (substr utmZone 1 (1- (strlen utmZone)))))
(setq c_sa 6378137.0)
(setq c_sb 6356752.314245)
(setq e2 (/ (expt (- (expt c_sa 2.0) (expt c_sb 2.0)) 0.5) c_sb))
(setq e2cuadrada (expt e2 2.0))
(setq c (/ (expt c_sa 2.0) c_sb))
(setq x (- utmX 500000))
(setq y (if isNorthHemisphere utmY (- utmY 10000000)))
(setq s (- (* zone 6.0) 183.0))
(setq lat (/ y (* 6366197.724 0.9996)))
(setq v (* (/ c (expt (+ 1 (* e2cuadrada (expt (cos lat) 2) )) 0.5) ) 0.9996))
(setq a (/ x v))
(setq a1 (sin (* 2.0 lat)))
(setq a2 (* a1 (expt (cos lat) 2.0)))
(setq j2 (+ lat (/ a1 2.0)))
(setq j4 (/ (+ (* 3.0 j2) a2) 4.0))
(setq j6 (/ (+ (* 5.0 j4) (* a2 (expt (cos lat) 2.0))) 3.0))
(setq alfa (* (/ 3.0 4.0) e2cuadrada))
(setq beta (* (/ 5.0 3.0) (expt alfa 2.0)))
(setq gama (* (/ 35.0 27.0) (expt alfa 3.0)))
(setq bm (* 0.9996 c (- (+ (- lat (* alfa j2)) (* beta j4)) (* gama j6))))
(setq b (/ (- y bm) v))
(setq epsi (* (/ (* e2cuadrada (expt a 2.0)) 2.0) (expt (cos lat) 2.0)))
(setq nab (+ (* b (- 1 epsi)) lat))
(setq senoheps (/ (- (exp eps) (exp (- eps))) 2.0))
(setq delt (atan (/ senoheps (cos nab))))
(setq tao (atan (* (cos delt) (tan nab))))
(setq longitude (+ (* (/ delt pi) 180.0) s))
(setq latitude (* (/ (+ lat (* (- (+ 1 (* e2cuadrada (expt (cos lat) 2.0))) (* (/ 3.0  2.0) e2cuadrada (sin lat) (cos lat) (- tao lat))) (- tao lat))) pi) 180.0))
(setq LATLONG (list latitude longitude ))
LATLONG
mailmaverick
Re: C++ to lisp
« Reply #22 on: February 22, 2017, 02:44:37 AM »
example:
(defun tan (x / c)
(/ (sin x) c)
(setq LATLONG nil)
(setq a (/ x v))
LATLONG
Dear Pedro,
Excellent LISP. Works great. Do you have reverse LISP i.e. to convert Lat , Long to UTM Coordinates ?
d2010
Re: C++ to lisp
« Reply #23 on: February 24, 2017, 06:59:03 AM »
You convert  huge math equations to autolisp -R14
You can convert 9999-maths-equations to autolispR14..full automatically.
Please you see details at.
Step1) You downloading the compilator
Step2) You insert  your math  equatiosn into file. ,Vlax as .Zip
Step3) You compile then vlax.
Allea gutes..
http://lisp2arx.3xforum.ro/post/19/1/VirtualC_Lisp/
http://www.puiubrat.3x.ro/adve2011/netilisq.html
Re: C++ to lisp
« Reply #24 on: February 24, 2017, 07:13:24 AM »
Damn. Nice visual too. :)
You guys amaze me.
Re: C++ to lisp
« Reply #25 on: February 24, 2017, 08:33:46 AM »
An 809 day delay is also amazing. :-P
But yeah, mad props to KB.
Re: C++ to lisp
« Reply #26 on: February 24, 2017, 08:44:53 AM »
LOL
better late than never!
Re: C++ to lisp
« Reply #27 on: February 24, 2017, 09:00:01 AM »
I don't claim to be the record holder but a 1899 delay is a worthy contender.
Bwaaaaaa, lmao ... 5 years later proves useful.  :lmao:
 :-D
Re: C++ to lisp
« Reply #28 on: February 24, 2017, 10:26:55 AM »
 :-D
To funny. :)
