Author Topic: Which virtual machine for AutoCAD?  (Read 16229 times)
Peter2
« on: August 23, 2014, 06:02:22 PM »
Hi
since 1.5  years I use VMWare Workstation for my AutoCADs (on Win 7 x64), and it works so-so (sometimes heavy graphic issues: delays, phantom images,..; sometimes crashes with USB headset). Now I lost 1.5 days with the update from 9 to 10 - all "VMWare tools" are not installed because the  "MSI error 1603". Now I'm really fed up - many postings of many frustrated users in many VMware-forums, no clear solution, old links in VMWare KB, no support from VMWare ("you have not paid support"). I'm in the mood to throw it in the trash-can.
So: Who uses VMs for AutoCAD? Which can be recommended for Autocad?
Have a nice sunday.
Peter
BricsCAD V23
ChrisCarlson
Re: Which virtual machine for AutoCAD?
« Reply #1 on: August 24, 2014, 09:45:42 AM »
Why do you need the VM?
Peter2
« Reply #2 on: August 24, 2014, 10:52:03 AM »
I need it because I have installed different versions of AutoCAD (onlyWin, XP and 7), and for different testings and configurations I separated it from my physical machine and need the snap-shot features of VM.
The drawings are rather simple, but with VMWare I have always delays and phantom-images using simple dialogues (although my  graphic is  a Nvidia K3000M - not the best, but should be enough)
Peter
BricsCAD V23
ChrisCarlson
« Reply #3 on: August 25, 2014, 08:40:17 AM »
Personally I'd recommend VirtualBox over VMWare but with that said  the oldest currently supported version of ACAD seems to be 2012. Using different versions, especially pre-2013 with post-2013 could  be problematic as the file versions changed.
Peter2
« Reply #4 on: August 25, 2014, 08:47:40 AM »
...the oldest currently supported version of ACAD seems to be 2012....
Virtual Box makes differences between different software-versions? (The file-version of DWG (2010 / 2013) are no problem for me)
Peter
Peter
BricsCAD V23
BlackBox
« Reply #5 on: August 25, 2014, 08:50:16 AM »
Historically I've used VMWare, however now that we've upgraded to Windows 8.1 I just use Client Hyper-V which is built into the OS... In addition to allowing me to test apps in different environments, Client Hyper-V also helps with administration of our Windows Server 2012 R2 environment, as I can manage physical server Hyper-V from my workstation.
HTH
Peter2
« Reply #6 on: August 25, 2014, 08:56:34 AM »
... to Windows 8.1 I just use Client Hyper-V which is built into the OS...
A quick view to the linked document shows that Hyper-V is available only in Win 8 - right?
Peter
BricsCAD V23
BlackBox
« Reply #7 on: August 25, 2014, 09:50:39 AM »
Correct; Microsoft built the Hyper-V (virtualization management console) into the OS starting with Windows 8, which has free upgrade to Windows 8.1.
As I understand it, you're still using Window 7, and I am unsure of your VLSC/MSDN account status, so this only applies with upgrade to Windows 8.1+ (presuming this functionality is not removed in Windows 9 next month?).
If you're a fellow Microsoft BizSpark member, simply download the Windows 8.1 Enterprise license from MSDN.
Cheers
Peter2
« Reply #8 on: August 25, 2014, 10:36:44 AM »
...upgrade to Windows 8.1+ ...
At the moment I don't have any membership or licences not any plans to upgrade tp Win 8;I will stay at 7.
Peter
BricsCAD V23
BlackBox
« Reply #9 on: August 25, 2014, 11:28:06 AM »
In that case, continuing with VMWare, or moving to VirtualBox as ChrisCarlson recommended appear to be your options.
Cheers
Peter2
« Reply #10 on: August 25, 2014, 11:36:46 AM »
But, if I understand him correctly, VirtualBox has problems with newer versions?
Peter
BricsCAD V23
BlackBox
« Reply #11 on: August 25, 2014, 12:13:26 PM »
Perhaps ChrisCarlson can clarify, as I do not use VirtualBox (I use Client Hyper-V); I find it strange that a VM host would pose issues for any AutoCAD application, as it just hosts a guest OS within each VM, and you should be able to install any OS compatible application within same, AFAIK.
ChrisCarlson
« Reply #12 on: August 26, 2014, 11:13:37 AM »
I was referencing the utilizing of different AutoCAD versions which have different file saving extensions; eg 2013 drawing vs 2010 drawing.
Windows XP is no longer supported in any capacity for the average company. Exemptions exist for critical infrastructure instances but it should not exist anywhere on your network. I'd also look into upgrading to Windows 8.1 or Windows 9 as mainstream support for Windows 7 will end in January of 2015.
If you are purely testing between different versions of AutoCAD I'd just suggest installing all the versions on your host machine. All of this doesn't explain why you need to test said drawing, lisp routine, program, marcro on various platforms. Just sounds like it will make a hassle and confusion while it fragments everything.
BlackBox
« Reply #13 on: August 26, 2014, 11:55:58 AM »
1+ multiple points, Chris.
dgorsman
« Reply #14 on: August 26, 2014, 02:42:08 PM »
... as mainstream support for Windows 7 will end in January of 2015.
Uhhhh... what?   :?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
