Author Topic: Another DWG insert as block in currend dwg, but replace existing blocks  (Read 1780 times)
MarioR
Hello,
i insert a extern dwg in my current dwg:
                string blockName = Path.GetFileNameWithoutExtension(blockPfadName);
                using (Database acBlockDatabase = new Database(false, true))
                    acBlockDatabase.ReadDwgFile(blockPfadName, FileOpenMode.OpenTryForReadShare, true, "");
                    acBlockDatabase.CloseInput(true);
                    if (transaction.StartTransaction())
                        acBTRId = transaction.AcDatabase.Insert(blockName, acBlockDatabase, true);
                        return true;
But the extern dwg contains also blocks. On insert this dwg as block print AutoCAD messages like
"Double defination of Block 1234 ignored"
How i can replace the "nested Blocks" from extern dwg into current dwg?
regards Mario
WILL HATCH
Re: Another DWG insert as block in currend dwg, but replace existing blocks
« Reply #1 on: August 06, 2014, 07:24:42 PM »
Instead of insert use wblockcloneobjects and set duplicaterecords to manglename
