Author Topic: move layout to another dwg  (Read 6118 times)
Bethrine
« on: August 01, 2014, 11:11:51 AM »
How? I need to combine two drawings as one, never done this before. Help! :D
Rob...
Re: move layout to another dwg
« Reply #1 on: August 01, 2014, 11:16:13 AM »
You can import the layout by right clicking on a layout tab or button and selecting "From Template". Change the file type to .dwg and browse to the other drawing. This will get you everything in paper space.
Copy/clip with base point (0,0) and paste to (0,0) to get model space and hope nothing overlaps.
CAD Tech
« Reply #2 on: August 01, 2014, 11:19:35 AM »
Open both drawings and use design center ( DC ).
Bethrine
« Reply #3 on: August 01, 2014, 11:39:33 AM »
Sweet! I am sure it will overlap so I will try DC or maybe pasting to a different coordinate.
Thank you both!  :angel: :angel:
« Reply #4 on: August 01, 2014, 11:56:41 AM »
If you haven't tried this routine it will knock you socks off.  8)
http://lee-mac.com/steal.html
NOT SURE
« Reply #5 on: August 01, 2014, 12:45:25 PM »
Here's a quick one that pulls in a certain Layout (Paperspace objects only) from one of our templates.
(vl-cmdf "._-LAYOUT" "_TEMPLATE" "awow_01" "container1")
Change "awow_01" to the drawing template name, and change "container1" to the desired Layout you'd need.
Although, I have to say that Steal from Lee is outstanding.
Bethrine
« Reply #6 on: August 01, 2014, 12:52:39 PM »
Looks right up my alley! Since I am new to this, is the folowing normal?:
« Reply #7 on: August 01, 2014, 01:11:03 PM »
yes it is! :) load it!!
Bethrine
« Reply #8 on: August 01, 2014, 01:15:50 PM »
yes sir!!!  :police:
Bethrine
« Reply #9 on: August 01, 2014, 01:32:32 PM »
 Great program!
Uh, was this supposed to happen? :?
« Reply #10 on: August 01, 2014, 01:45:39 PM »
my suggestion
Open both drawings
set current tab in each to MODEL
go to view tab
Tile the drawings
in the file that has stuff that needs to be in the other file
select everything in model space
RT-Click and wait.....when the cursor changes
continue holding the rt button down and drag the data into the destination drawing.....
you will get options - paste here - paste to original coordinates....choose
Then using design center CTRL+2
use open drawings tab
find LAYOUTS
select those required Rt-Click chose ADD LAYOUTS
the two files are now one.....
Bethrine
« Reply #11 on: August 01, 2014, 01:55:05 PM »
I think it's something to do with one of the drawings. I'm having the same problem with all three methods.  :-(
Note: Also, I need to update the title block from an old one in one of them.
Bethrine
« Reply #12 on: August 01, 2014, 01:58:21 PM »
I'm trying this one more time...think I may not have used 0,0 properly.
Bethrine
« Reply #13 on: August 01, 2014, 02:01:17 PM »
Okay, when looking at the "top" one is upside down from the other, lol.
ChrisCarlson
« Reply #14 on: August 01, 2014, 02:04:53 PM »
I have no idea why AutoDesk initiated this
At the command line enter "secureload" , "0" then enter
