Author Topic: move layout to another dwg  (Read 6151 times)
Bethrine
Re: move layout to another dwg
« Reply #15 on: August 01, 2014, 02:16:13 PM »
I have no idea why AutoDesk initiated this
At the command line enter "secureload" , "0" then enter
Initiated what?
What does that do?
...the program worked great, I'm trying it again as DC won't load 2 of the layouts. I had to rotate around 0,0 by 180 degrees. lol
Bethrine
« Reply #16 on: August 01, 2014, 02:19:31 PM »
That worked great! Now I just have to correct some visibility issues in the viewports.
Thank you all!
Rob...
« Reply #17 on: August 01, 2014, 02:29:11 PM »
 :lmao:
CAD Tech
Bethrine
« Reply #18 on: August 01, 2014, 02:53:54 PM »
So any ideas on what happened to the dimensions? (This has been an on on and off problem for me.)
Greg B
  • Tell me a Joke!
« Reply #19 on: August 01, 2014, 03:02:13 PM »
Dimension in a viewport and outside a viewport?
Bethrine
« Reply #20 on: August 01, 2014, 03:23:01 PM »
I always dimension in paper space on viewport entities. Checking drawing....
It's the same as I do it.
Wait...you can dimension in both?...at the same time? I'm missing something here.
When I delete and re-dimension, it comes out correct again.
« Last Edit: August 01, 2014, 03:28:29 PM by Bethrine »
Bethrine
« Reply #21 on: August 04, 2014, 10:57:33 AM »
 :lol: Yeah! I ended up using clipboard to copy and paste model space at 0,0 into the new drawing after making sure the view was the same in both drawings (I used "top") and then I used CAB's program and in a wink I was done except for turning off some layers in some viewports. Awesome stuff! Thanks again!!!
