Author Topic: TheSwamp will be offline in the morning  (Read 15078 times)
Re: TheSwamp will be offline in the morning
« Reply #30 on: August 03, 2014, 08:58:14 AM »
Mark, the codes placed into Autolisp code tags are black/white... Shouldn't that be in color?
Yeah, give it a couple days and I'll make the adjustments. Or maybe we can get Se7en to do it! ;)
Everyone:
I will see what I can do to fix the GeSHi code tags. Not sure where the problems is so I will need to spend some time investigating what the status is. I am hopping it's just a setting on the forum. I also have some freelance work to complete first so it may take me a few hours to even get started (and potentially an hour or two to fix the problem).
Mark, Question: Do we want to move the AutoLisp help to a different directory other than my user directory on the server (right now, it resides in /john/www/alisphelp/. Do we want that in /www/)?
« Reply #31 on: August 03, 2014, 09:16:03 AM »
We can do in the near future if you'd like. Makes no never-mind to me though. :)
« Reply #32 on: August 03, 2014, 09:33:44 AM »
Thanks Mark
And  John for the Code Tags
FYI not notification email on new post to subscribed threads.
« Last Edit: August 03, 2014, 09:37:02 AM by CAB »
« Reply #33 on: August 03, 2014, 09:48:23 AM »
Neither do I. Let's leave it where it is then.
« Reply #34 on: August 03, 2014, 09:48:48 AM »
Thanks Mark
No problem CAB.
« Reply #35 on: August 03, 2014, 07:05:01 PM »
Should be all fixed now everyone. :)
« Reply #36 on: August 03, 2014, 07:20:37 PM »
Thank you John, looks to be working well.
« Reply #37 on: August 03, 2014, 08:17:54 PM »
Thanks 0111.
« Reply #38 on: August 03, 2014, 08:34:07 PM »
Glad I could help. :)
« Reply #39 on: August 03, 2014, 09:44:33 PM »
Good Morning Mr T
Do you need to adjust the server clock by 1 hour ??
I just needed to re-select  (auto detect) in the Look and Layout -> Time Offset field in my profile.
Was set to 15, needed to be 14
Bethrine
« Reply #40 on: August 04, 2014, 10:12:36 AM »
Everything looks great from my end!  :lol:
Bethrine
« Reply #41 on: August 04, 2014, 10:18:53 AM »
Lovin the Prince of Darkness theme (thanks Mayhem for pointing that out)...but (see below):
...maybe this should be moved to "Display Problems at the Swamp"? Also, The "cracked" theme doesn't come up for me. I get that generic list looking thingy.
« Last Edit: August 04, 2014, 10:40:37 AM by Bethrine »
« Reply #42 on: August 04, 2014, 11:16:52 AM »
I will move the theme over later today.
« Reply #43 on: August 04, 2014, 08:29:34 PM »
  • The old Swamp favicon ( ) appears to be missing
  • The old Smileys (e.g. - my favourite set) are not showing
those two should be working now.
« Reply #44 on: August 04, 2014, 08:32:25 PM »
