Author Topic: ObjectDBX list  (Read 3191 times)
GDF
ObjectDBX list
« on: June 18, 2014, 03:00:16 PM »
This is from Alan's  Replace Text routine using ObjectDBX. See comments in red below.
(defun c:replacetext (/ oldtx newtx)
  ;;  text to replace ("PARTY WALL" "COMMON WALL")
  (setq oldtx (strcase (getstring t "* Enter text to be replaced:")))
  (setq newtx (strcase (getstring T "* Enter new text:")))
  (TextReplaceDBX 3 ; both Model & Paper Space
    '(("OldText" "NewString")
      ;;("PARTY WALL" "COMMON WALL")  ;;this works
      (list oldtx newtx)  ;;this does not work
reltro
Re: ObjectDBX list
« Reply #1 on: June 18, 2014, 03:52:45 PM »
Whats the question?
Try:
    (list
        '("OldText" "NewString")
        (list oldtx newtx)
reltro
GDF
Re: ObjectDBX list
« Reply #2 on: June 18, 2014, 04:09:30 PM »
Thanks, but only this works. I just wanted to know why.
reltro
Re: ObjectDBX list
« Reply #3 on: June 18, 2014, 04:26:57 PM »
What is THIS?
I can't follow u, can't test anything...
ask a question so u are going to have an answer...
owenwengerd
Re: ObjectDBX list
« Reply #4 on: June 18, 2014, 04:31:37 PM »
When you use the quote function to form a quoted list as in '("the" "brown" "fox"), the list contents will not be evaluated. Therefore, your nested (list X Y) will not be evaluated. You can't quote the entire list in that case, as reltro already showed.
GDF
Re: ObjectDBX list
« Reply #5 on: June 18, 2014, 05:31:42 PM »
Here is where the original routine can be found:
http://www.theswamp.org/index.php?topic=14703.msg177823#msg177823
;;  TextReplace.lsp
;;  CAB 02/19/07 version 3
I just wanted to add this to Alan's routine and have it evaluated:
  (setq oldtx (strcase (getstring T "* Enter text to be replaced")))
  (setq newtx (strcase (getstring T "* Enter new text")))
(list '("OldText" "NewString") (list oldtx newtx) )
GDF
Re: ObjectDBX list
« Reply #6 on: June 18, 2014, 05:36:22 PM »
It works now...I just can't get my head around lists.
Re: ObjectDBX list
« Reply #7 on: June 18, 2014, 08:18:24 PM »
As Owen said this doesn't work
      (list oldtx newtx)
because this quote ' stops any further evaluation so the imbedded list is ignored.
GDF
Re: ObjectDBX list
« Reply #8 on: June 19, 2014, 10:05:45 AM »
      (list oldtx newtx)
Alan, all I know is the following works:  (list '("OldText" "NewString") (list oldtx newtx))
Your old routine works perfectly now and saves me a lot of time editing dtext in dozens of drawings.
GDF
Re: ObjectDBX list
« Reply #9 on: June 20, 2014, 09:59:41 AM »
Here is Alan's TextReplace routine with my changes. I added Lee's LM:EditBox sub function, and Tony Tanzillo's Directory-Dia sub fuction.
Thanks to all that responded to my poorly worded question. Also thanks to Reltro and Owen for their help.
Gary
Re: ObjectDBX list
« Reply #10 on: June 20, 2014, 10:48:23 AM »
I'm sure you tried Lee's routine too.
http://www.theswamp.org/index.php?topic=32777.0
GDF
Re: ObjectDBX list
« Reply #11 on: June 20, 2014, 10:59:45 AM »
Son of a Gun
No...I should have know Lee had one.
I'll search better next time.
