Author Topic: Losing selected object in while  (Read 1628 times)
cadplayer
« on: May 16, 2014, 05:20:26 AM »
Hello!
Have hade sombody else the same problem. If I select a block with an attribut and set with grread-coordinates to
attributposition it should move the attribut on cursor, so long I move cursor.
-works fine
Next is if I come with mousecursor to a POLYLINE it should rotate attribut in right direction or parallel to a POLYLINE
-works fine
Sometimes i must in same procedure rotate attribute with 180 degrees
-works find
But here I have my problem, I can´t move attributposition
I get this error and I have seen my attributobject is nil so it´s lost. How can I solve this
error: bad argument type: lentityp nil
(defun c:a (/ ss gr pt ent typ pt end-pt pl-len pt09 pt10 pt11 werte VLAobj )
    (princ "\n Attribute freistellen...")
  (defun GetVlaObj (ent)
    (vlax-ename->vla-object ent)
  (defun GetDXFObj (ent)
    (vlax-vla-object->ename ent)
    (if (setq ss (ssget "_:E" '((0 . "INSERT"))))
      (setq VLAobj (GetVlaObj (cdr (assoc -1 (gettag (ssname ss 0) "NIVÅ")))))
        (while (and (setq gr (grread t 13 0))
    (/= (cadr gr) 13)
                    (/= (car gr) 25)
    (not (eq 3 (car gr)))
     (eq 5 (car gr))
  (redraw)
  (if (setq ent (nentselp (cadr gr)))
    (setq typ (cdr (assoc 0 (entget (car ent)))))
    (or
      (= "LWPOLYLINE" typ)
      (= "LINE" typ)
      (setq pt (cadr ent))
      (setq end-pt (vlax-curve-getEndPoint ( GetVlaObj (car ent))))
      (if (>= (vlax-curve-getDistAtPoint ( GetVlaObj (car ent)) end-pt)
                         (setq pl-len (vlax-curve-getDistAtPoint ( GetVlaObj (car ent))
        (setq pt10  (vlax-curve-getClosestPointTo ( GetVlaObj (car ent)) pt))
(setq pt11 (if (null (vlax-curve-getPointAtDist ( GetVlaObj (car ent)) (+ pl-len 0.01)))
                                         (vlax-curve-getPointAtDist ( GetVlaObj (car ent)) pl-len)
(setq pt09 (if (null (vlax-curve-getPointAtDist  ( GetVlaObj (car ent)) (- pl-len 0.01)))
(setq werte (list ( GetVlaObj (ssname ss 0)) (angle pt09 pt11)))
(vla-put-rotation (car werte) (cadr werte))
(setq a (getstring "\nRotate 180grad / Postion: [r]otate / <c>ontinue"))
  ((= a "r")
   (vla-put-rotation (car werte) (+ pi (cadr werte)))
   (GetDXFObj VLAobj)
  ((or (= a "") (= a "c"))
;;;    (princ (vl-princ-to-string gr))
   (redraw)
   (entmod (subst (cons 10 (cadr gr)) (assoc 10 (entget (GetDXFObj VLAobj))) (entget (GetDXFObj VLAobj))))
;;;   (vlax-put-property VLAobj 'InsertionPoint (vlax-3d-point (cadr gr)))
this is only a selecting methode for attrib in a block
