There are many errors, missing quotes.
Like this
("ARHEADER" "S-Beam" white Phamton2) ; use white & Phamton2
should be this
("ARHEADER" "S-Beam" "white" "Phamton2") ; use white & Phamton2
and incomplete code like this:
("ARINTELEV" ;<==== purpe
when in VLIDE you will not be allowed to load the code until you fix these incomplete code errors.
The missing quotes will cause errors when you try to run the code.
These items must be cleaned up.
If you don't have a new layer defined yet comment out the line
;; ("ARINTELEV" ;<==== purpe
Your function (defun MergeLayerP has a P in the name but you call it with (MergeLayer LayList)
this will never work, the programming languages are very particular about such things.
Try again!
Yes shark fishing is a lot of fun. If you are not going to eat them put them back.
I have a few shark stories but I usually wait till I have a few rum & cokes before I
tell them. The fish always get bigger in proportion to the alcohol consumed.
