Next fail, is Autodesk's negative opt in for Desktop Analytics... It clearly states that you can disable it through the help menu, but there were no search results for "desktop analytics." For now, simply use the DESKTOPANALYTICS Command, and disable the checkbox... Not sure where this is stored in the registry yet, but when I do, I'm posting a routine to disabled it.
