Author Topic: Auto Arrange  (Read 10079 times)
liuhaixin88
Auto Arrange
« on: April 28, 2014, 10:52:18 AM »
Who has seen anything like it ?  lisp ,fas,vlx ?
Auto Arrange , minimal area . Choose arrange clearance & quantity.
[BTW:Authors blame I issued his pictures , SO I was delete it ]
« Last Edit: May 02, 2014, 03:27:00 AM by liuhaixin88 »
ChrisCarlson
Re: Auto Arrange
« Reply #1 on: April 28, 2014, 10:55:26 AM »
Arrange what?
Blocks?
Text?
Mleaders?
liuhaixin88
Re: Auto Arrange
« Reply #2 on: April 28, 2014, 11:03:38 AM »
Arrange what?
Blocks?
Text?
Mleaders?
I just upload the image.
BlackBox
Re: Auto Arrange
« Reply #3 on: April 28, 2014, 11:30:28 AM »
A few Commands come to mind... Array, Measure, Divide, etc.
liuhaixin88
Re: Auto Arrange
« Reply #4 on: April 28, 2014, 12:33:50 PM »
Hello ,BB
It's Not so easy, need related to the algorithm, Like the minimum bounding box.
First ,I don't know how to arrange for the smallest area.
Found a related demonstration:
« Last Edit: May 02, 2014, 03:27:49 AM by liuhaixin88 »
dgorsman
Re: Auto Arrange
« Reply #5 on: April 28, 2014, 02:09:13 PM »
Look for nesting algorithms.  Should be several threads here on the subject if memory serves.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
ribarm
  • Marko Ribar, architect
Re: Auto Arrange
« Reply #6 on: April 28, 2014, 06:30:40 PM »
This is how I would arrange 23 3D entities in 3D... Like in 2D and in my version linear arrangement prevails - only in Z direction...
See attachment...
M.R. on Youtube
liuhaixin88
Re: Auto Arrange
« Reply #7 on: April 28, 2014, 10:52:27 PM »
See attachment...
Ribarm, I know you proficient algorithm.The first person.
Can you help me?
liuhaixin88
Re: Auto Arrange
« Reply #8 on: April 29, 2014, 10:19:08 PM »
See attachment...
Please,marko, I need your help. Any file formats all ok! (VLX ,FAS,ARX)
ChrisCarlson
Re: Auto Arrange
« Reply #9 on: April 30, 2014, 07:56:28 AM »
Download Nestlib Online from the Acad App exchange
ribarm
Re: Auto Arrange
« Reply #10 on: April 30, 2014, 11:03:54 AM »
This is similar to your 11.gif... It uses rotate&copy, but not mirror... Tested on simple LWPOLYLINES like on posted 11.gif...
  1. (defun c:rotarrange ( / adoc msp LM:MinEncCircle LM:RemoveWithFuzz LM:GetInsideAngle LM:3PCircle mid LM:ConvexHull LM:Clockwise-p LM:LWPoly->List pl n ri vl c plc xl ip p ipl d dl dminv dminvl dmaxv dmaxvl dmax1 dmax2 ipp pp ippl tst dmaxl dmin dlst->dmin )
  2.
  3.   (setq msp (vla-get-modelspace adoc))
  4.
  5.   (defun LM:MinEncCircle ( lst / _sub )
  6.
  7.       (defun _sub ( p1 p2 l1 / a1 a2 l2 p3 p4 )
  8.           (setq l2 (LM:RemoveWithFuzz (list p1 p2) l1 1e-8)
  9.                 p3 (car l2)
  10.                 a1 (LM:GetInsideAngle p1 p3 p2)
  11.           )
  12.           (foreach p4 (cdr l2)
  13.               (if (< (setq a2 (LM:GetInsideAngle p1 p4 p2)) a1)
  14.                   (setq p3 p4 a1 a2)
  15.               )
  16.           )
  17.           (cond
  18.               (   (<= (/ pi 2.0) a1)
  19.                   (list (mid p1 p2) (/ (distance p1 p2) 2.0))
  20.               )
  21.               (   (vl-some
  22.                       (function
  23.                           (lambda ( a b c )
  24.                               (if (< (/ pi 2.0) (LM:GetInsideAngle a b c)) (_sub a c l1))
  25.                           )
  26.                       )
  27.                       (list p1 p1 p2) (list p2 p3 p1) (list p3 p2 p3)
  28.                   )
  29.               )
  30.               (   (LM:3PCircle p1 p2 p3)   )
  31.           )
  32.       )
  33.
  34.       ((lambda ( lst ) (_sub (car lst) (cadr lst) lst)) (LM:ConvexHull lst))
  35.   )
  36.
  37.   ;; Remove With Fuzz  -  Lee Mac
  38.   ;; Removes items from a list which are equal to a supplied tolerance
  39.
  40.   (defun LM:RemoveWithFuzz ( l1 l2 fz )
  41.       (vl-remove-if
  42.           (function
  43.               (lambda ( a )
  44.                   (vl-some
  45.                       (function (lambda ( b ) (equal a b fz)))
  46.                       l1
  47.                   )
  48.               )
  49.           )
  50.           l2
  51.       )
  52.   )
  53.
  54.   ;; Get Inside Angle  -  Lee Mac
  55.   ;; Returns the smaller angle subtended by three points with vertex at p2
  56.
  57.   (defun LM:GetInsideAngle ( p1 p2 p3 )
  58.       (   (lambda ( a ) (min a (- (+ pi pi) a)))
  59.           (rem (+ pi pi (- (angle p2 p1) (angle p2 p3))) (+ pi pi))
  60.       )
  61.   )
  62.
  63.   ;; 3-Point Circle  -  Lee Mac
  64.   ;; Returns the Center and Radius of the Circle defined by
  65.   ;; the supplied three points.
  66.
  67.   (defun LM:3PCircle ( p1 p2 p3 / cn m1 m2 )
  68.       (setq m1 (mid p1 p2)
  69.             m2 (mid p2 p3)
  70.       )
  71.       (list
  72.           (setq cn
  73.               (inters
  74.                   m1 (polar m1 (+ (angle p1 p2) (/ pi 2.)) 1.0)
  75.                   m2 (polar m2 (+ (angle p2 p3) (/ pi 2.)) 1.0)
  76.                   nil
  77.               )
  78.           )
  79.           (distance cn p1)
  80.       )
  81.   )
  82.
  83.   ;; Midpoint - Lee Mac
  84.   ;; Returns the midpoint of two points
  85.
  86.   (defun mid ( a b )
  87.       (mapcar (function (lambda ( a b ) (/ (+ a b) 2.0))) a b)
  88.   )
  89.
  90.   ;; Convex Hull  -  Lee Mac
  91.   ;; Implements the Graham Scan Algorithm to determine the
  92.   ;; Convex Hull of a list of points.
  93.
  94.   (defun LM:ConvexHull ( lst / hul p0 )
  95.       (cond
  96.           (   (< (length lst) 4)
  97.               lst
  98.           )
  99.           (   t
  100.               (setq p0 (car lst))
  101.               (foreach p1 (cdr lst)
  102.                   (if (or (< (cadr p1) (cadr p0))
  103.                           (and (= (cadr p1) (cadr p0)) (< (car p1) (car p0)))
  104.                       )
  105.                       (setq p0 p1)
  106.                   )
  107.               )
  108.               (setq lst
  109.                   (vl-sort lst
  110.                       (function
  111.                           (lambda ( a b / c d )
  112.                               (if (or (equal (setq c (angle p0 a)) (setq d (angle p0 b)) 1e-8) (and (or (equal c 0.0 1e-8) (equal c (* 2 pi) 1e-8)) (or (equal d 0.0 1e-8) (equal d (* 2 pi) 1e-8))))
  113.                                   (< (distance (list (car p0) (cadr p0)) a) (distance (list (car p0) (cadr p0)) b))
  114.                                   (< c d)
  115.                               )
  116.                           )
  117.                       )
  118.                   )
  119.               )
  120.               (setq hul (list (caddr lst) (cadr lst) (car lst)))
  121.               (foreach pt (cdddr lst)
  122.                   (setq hul (cons pt hul))
  123.                   (while (and (caddr hul) (LM:Clockwise-p (caddr hul) (cadr hul) pt))
  124.                       (setq hul (cons pt (cddr hul)))
  125.                   )
  126.               )
  127.               hul
  128.           )
  129.       )
  130.   )
  131.
  132.   ;; Clockwise-p  -  Lee Mac
  133.   ;; Returns T if p1,p2,p3 are clockwise oriented or collinear
  134.
  135.   (defun LM:Clockwise-p ( p1 p2 p3 )
  136.       (<  (-  (* (- (car  p2) (car  p1)) (- (cadr p3) (cadr p1)))
  137.               (* (- (cadr p2) (cadr p1)) (- (car  p3) (car  p1)))
  138.           )
  139.           1e-8
  140.       )
  141.   )
  142.
  143.   ;; LWPolyline to Point List  -  Lee Mac
  144.   ;; Returns a list of points describing the supplied LWPolyline
  145.
  146.   (defun LM:LWPoly->List ( ent n / der di1 di2 inc lst par )
  147.       (setq par 0)
  148.       (repeat (cdr (assoc 90 (entget ent)))
  149.           (if (setq der (vlax-curve-getsecondderiv ent par))
  150.               (if (equal der '(0.0 0.0 0.0) 1e-8)
  151.                   (setq lst (cons (vlax-curve-getpointatparam ent par) lst))
  152.                   (if
  153.                       (setq di1 (vlax-curve-getdistatparam ent par)
  154.                             di2 (vlax-curve-getdistatparam ent (1+ par))
  155.                       )
  156.                       (progn
  157.                           (setq inc (/ (- di2 di1) n))
  158.                           (while (< di1 di2)
  159.                               (setq lst (cons (vlax-curve-getpointatdist ent di1) lst)
  160.                                     di1 (+ di1 inc)
  161.                               )
  162.                           )
  163.                           (if (equal (vlax-curve-getpointatdist ent di1) (vlax-curve-getendpoint ent) 1e-8)
  164.                               (setq lst (cons (vlax-curve-getendpoint ent) lst))
  165.                           )
  166.                       )
  167.                   )
  168.               )
  169.           )
  170.           (setq par (1+ par))
  171.       )
  172.       lst
  173.   )
  174.
  175.   (while (or (not (setq pl (car (entsel "\nPick LWPOLYLINE shape")))) (not (eq (cdr (assoc 0 (entget pl))) "LWPOLYLINE"))))
  176.   (initget 7)
  177.   (setq n (getint "\nSpecify rotational derivation of full rotation - 360 degree / ? : "))
  178.   (setq ri (/ 360.0 n))
  179.   (setq ri (* (/ ri 180.0) pi))
  180.   (setq c (car (LM:MinEncCircle (LM:LWPoly->List pl 25))))
  181.   (repeat n
  182.     (if plc (entdel (vlax-vla-object->ename plc)))
  183.     (vla-rotate (vlax-ename->vla-object pl) (vlax-3d-point c) ri)
  184.     (setq vl (LM:LWPoly->List pl 36))
  185.     (foreach v vl
  186.       (setq xl (vla-addxline msp (vlax-3d-point v) (vlax-3d-point (mapcar '+ v '(1.0 0.0 0.0)))))
  187.       (setq ip (vlax-invoke xl 'intersectwith (vlax-ename->vla-object pl) acextendnone))
  188.       (if (/= (length ip) 3)
  189.         (progn
  190.           (repeat (/ (length ip) 3)
  191.             (setq p (list (car ip) (cadr ip) (caddr ip)))
  192.             (setq ip (cdddr ip))
  193.             (setq ipl (cons p ipl))
  194.           )
  195.           (foreach p ipl
  196.             (setq d (distance v p))
  197.             (setq dl (cons d dl))
  198.           )
  199.           (setq dminv (cadr (vl-sort dl '<)))
  200.           (setq dmaxv (apply 'max dl))
  201.           (if dminv (setq dminvl (cons dminv dminvl)))
  202.           (if dmaxv (setq dmaxvl (cons dmaxv dmaxvl)))
  203.           (setq ipl nil dl nil)
  204.         )
  205.       )
  206.       (entdel (vlax-vla-object->ename xl))
  207.     )
  208.     (setq dmax1 (apply 'max dminvl))
  209.     (setq dminvl nil)
  210.     (setq dmax2 (apply 'max dmaxvl))
  211.     (setq dmaxvl nil)
  212.     (setq plc (vla-copy (vlax-ename->vla-object pl)))
  213.     (vla-move plc (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point (list dmax1 0.0 0.0)))
  214.     (setq ipp (vlax-invoke plc 'intersectwith (vlax-ename->vla-object pl) acextendnone))
  215.     (repeat (/ (length ipp) 3)
  216.       (setq pp (list (car ipp) (cadr ipp) (caddr ipp)))
  217.       (setq ipp (cdddr ipp))
  218.       (setq ippl (cons pp ippl))
  219.     )
  220.     (foreach p ippl
  221.       (if (vl-some '(lambda ( x ) (equal x p 1e-8)) vl) (setq tst (cons t tst)) (setq tst (cons nil tst)))
  222.     )
  223.     (if (not (eval (cons 'and tst)))
  224.       (progn
  225.         (vla-move plc (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point (list (- dmax1) 0.0 0.0)))
  226.         (vla-move plc (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point (list dmax2 0.0 0.0)))
  227.         (setq dmaxl (cons dmax2 dmaxl))
  228.       )
  229.       (setq dmaxl (cons dmax1 dmaxl))
  230.     )
  231.     (setq tst nil ippl nil)
  232.     (vla-regen adoc 1)
  233.   )
  234.   (setq dmin (apply 'min dmaxl))
  235.   (setq dmaxl (reverse dmaxl))
  236.   (setq dlst->dmin (reverse (member dmin (reverse dmaxl))))
  237.   (foreach d dlst->dmin
  238.     (if plc (entdel (vlax-vla-object->ename plc)))
  239.     (vla-rotate (vlax-ename->vla-object pl) (vlax-3d-point c) ri)
  240.     (setq plc (vla-copy (vlax-ename->vla-object pl)))
  241.     (vla-move plc (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point (list d 0.0 0.0)))
  242.     (vla-regen adoc 1)
  243.   )
  244.   (princ)
  245. )
  246.
HTH
« Last Edit: June 19, 2019, 12:57:07 AM by ribarm »
M.R. on Youtube
ribarm
Re: Auto Arrange
« Reply #11 on: May 01, 2014, 02:56:08 AM »
Now, above posted code works and with more complex shapes, but only with LWPOLYLINE with straight segments (edges)...
M.R.
M.R. on Youtube
liuhaixin88
Re: Auto Arrange
« Reply #12 on: May 01, 2014, 08:48:47 PM »
M.R.
Marko, Thanks very much for your hard work.
Two objects  are rotated counterclockwise. I think , when rotated counterclockwise later, one objects rotated counterclockwise, one objects rotated clockwise.
Q1241274614
Re: Auto Arrange
« Reply #13 on: May 01, 2014, 11:30:03 PM »
After combination, such a minimum area.
http://www.theswamp.org/index.php?topic=46636.0
« Last Edit: May 01, 2014, 11:34:57 PM by Q1241274614 »
liuhaixin88
Re: Auto Arrange
« Reply #14 on: May 02, 2014, 12:40:17 AM »
Thanks for providing ideas.
« Last Edit: May 02, 2014, 03:31:38 AM by liuhaixin88 »
