Author Topic: Are entity names permanent ?  (Read 2121 times)
mailmaverick
« on: April 09, 2014, 06:35:41 AM »
Are entity names given by (car (entsel)) or  (ssname ss (setq n (1- n))) permanent in a drawing ?
By permanent I mean that the entity names are same for a particular entity (line / polyline / circle / ellipse etc)  even if we open a drawing after few days in a different computer ?
If not, then what else is permanent for an entity ?
Re: Are entity names permanent ?
« Reply #1 on: April 09, 2014, 06:40:23 AM »
RTFM
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-9CB07C25-4439-445D-B1B3-92174C53C571
Entity names assigned to objects in a drawing are only in effect during the current editing session. The next time you open the drawing, AutoCAD assigns new entity names to the objects. You can use an object's handle to refer to it from one editing session to another.
irneb
« Reply #2 on: April 09, 2014, 06:45:09 AM »
RTFM
:lmao: Damn! I was expecting a "standard" No! answer ... but this takes the cake!
Hint to the OP: Look for something regarding Handles.
snownut2
  • Bricscad 22 Ultimate
« Reply #3 on: April 09, 2014, 07:04:02 AM »
RTFM
RTFM = Read The F&^%#$% Memo ?
« Reply #4 on: April 09, 2014, 07:05:51 AM »
« Reply #5 on: April 09, 2014, 07:14:05 AM »
lol, kid gloves and sledge hammers, we haz variety folks
mailmaverick
« Reply #6 on: April 09, 2014, 08:26:13 AM »
So it means  (cdr (assoc 5 (entget ent)))) for every entity is permanent throughout the lifespan of the entity ?
« Reply #7 on: April 09, 2014, 08:28:50 AM »
No. Read the Help quote I posted.
Yes, If the ent in manually selected in the session.
« Last Edit: April 09, 2014, 08:38:52 AM by Kerry »
mailmaverick
« Reply #8 on: April 09, 2014, 08:38:43 AM »
Dear Kerry,
(cdr (assoc 5 (entget ent)))) returns the handle for the entity. See following link :-
http://www.autodesk.com/techpubs/autocad/acadr14/dxf/common_group_codes_for_graphical_objects_al_u05_c.htm
It is mentioned that Group Code 5 returns the entity handle.
As per the Help quote provided by you :-
It means that handles are permanent. Then, why (cdr (assoc 5 (entget ent)))) will not be permanent ?
« Reply #9 on: April 09, 2014, 08:58:03 AM »
If you want to convert a handle to entityName look at handent (AutoLISP)
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-AF6DD533-1A24-4687-96EB-F03F26050C07
This is one way to obtain and re-use the data
  1.
  2. (setq ent (car ( entsel)))                           ; <Entity name: 7ffffb05b60>
  3. (setq handleString (cdr (assoc 5 (entget ent))))     ; "3D6"
  4.
  5.
  6. ;; --> Save the handleString
  7.
  8. ;; --> restore the handleString
  9.
  10. (setq ent (handent handleString))                    ; <Entity name: 7ffffb05b60>
mailmaverick
« Reply #10 on: April 09, 2014, 09:05:15 AM »
« Reply #11 on: April 09, 2014, 09:09:03 AM »
