Author Topic: List of all variables used in a defun  (Read 5136 times)
Re: List of all variables used in a defun
« Reply #15 on: April 10, 2014, 08:45:56 PM »
Thank you for that statement Michael.
I have an expectation that people will make an effort to help themselves. I can understand how a pre-digested solution may be more acceptable.
« Reply #16 on: April 10, 2014, 08:54:46 PM »
You're most welcome KB. There are basically 2 types of people. I can see why'd you'd expect, and likely prefer the second variety because they have a far great probability of becoming teachers like yourself, whereas the odds the first type would go on to teach is highly improbable.
owenwengerd
« Reply #17 on: April 10, 2014, 09:54:58 PM »
I think my position on this is pretty well known, but I'd just add that I think there is more to the story than "two types of people". People adapt to their environment. I think that to a larger extent than many here realize, it's really all the same type of people -- but they have adapted to the environment. Take heed.
