Author Topic: leader  (Read 3023 times)
Q1241274614
leader
« on: April 03, 2014, 10:42:02 AM »
Select AAAAAA, BBBBBB and leader move together.
Select BBBBBB, AAAAAA and leader move together.
Re: leader
« Reply #1 on: April 03, 2014, 10:49:17 AM »
You could use the STRETCH command or just use an MLEADER.
Q1241274614
Re: leader
« Reply #2 on: April 03, 2014, 12:24:15 PM »
THANK!I want to choose AAAAAA or BBBBBB!
MLEADER?
Re: leader
« Reply #3 on: April 03, 2014, 12:40:24 PM »
MLEADER?
I'm sorry .. I don't understand what you are trying to do.
PKENEWELL
Re: leader
« Reply #4 on: April 03, 2014, 02:41:51 PM »
MLEADER?
If I understand correctly what you mean. Yes - you can use an MLEADER:
  • Set up and MLEADERSTYLE; Start the MLEADERSTYLE command, then create a new style or select "Modify" for the standard style. Then go to the tab "Content", and the section "leader connection" at the bottom left. Select "Underline top line" for both left attachment and right attachment combo-boxes. Set the other options as desired, then select "OK" to set the options. Make sure the leader style you created / modified is current by selecting it in the list and selecting the "Set Current" button. Close out of the leader style dialog box.
  • Start the MLEADER command and create a leader with 2 lines of text. You can then stretch the leader either by selecting the grip for the last point on the leader before the dogleg (if present), or by selecting the grip for the text.
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
Q1241274614
Re: leader
« Reply #5 on: April 03, 2014, 08:35:35 PM »
I use cad2004. without mleader!
PKENEWELL
Re: leader
« Reply #6 on: April 04, 2014, 09:54:37 AM »
In that case your only option is to create a Visual LISP program with reactors to control the movement of the leader along with the text objects. Perhaps some of the others here have dealt with this kind of reactor before and can help you get started?
ChrisCarlson
Re: leader
« Reply #7 on: April 04, 2014, 10:04:07 AM »
@ $100 / labor hour if it takes you more than 12 hours to solve this problem, you could have upgraded to ACAD2013.
PKENEWELL
Re: leader
« Reply #8 on: April 04, 2014, 10:21:14 AM »
:laugh:
cadtag
Re: leader
« Reply #9 on: April 04, 2014, 11:26:53 AM »
not any more.....  2015, but your numbers will be different.  also add in the PC & OS cost
ChrisCarlson
Re: leader
« Reply #10 on: April 04, 2014, 12:03:46 PM »
Couldn't he purchase say ACAD2013 from Amazon and still install it?
cadtag
Re: leader
« Reply #11 on: April 04, 2014, 12:23:36 PM »
legally????  I don't believe so. the full version f 2013 shows up as 'unavailable'.
2013  LT Maybe -- if some one still has unopened/unregistered retail boxes, but that won't get the OP LISP.
Q1241274614
Re: leader
« Reply #12 on: April 07, 2014, 02:41:02 PM »
ENTMAKE
