Author Topic: ** Error: no function definition: VLA-GET-OBJECTID32 **  (Read 12946 times)
Re: ** Error: no function definition: VLA-GET-OBJECTID32 **
« Reply #30 on: April 25, 2014, 11:26:02 AM »
Damn. I have to get AutoCAD 2015 installed. :police:
Thanks for letting me know Ron.
« Reply #31 on: April 25, 2014, 11:32:42 AM »
Glad to help  8)
« Reply #32 on: April 25, 2014, 11:36:41 AM »
Regardless that vla-setblocktablerecordid will accept a string ... given that vla-get-objectid returns an int aren't you tempted to return same from your alt?
« Reply #33 on: April 25, 2014, 02:13:07 PM »
That would probably be a good idea.
Would you know why (atoi "140694991308416") returns 2147483647 ?
ribarm
  • Marko Ribar, architect
« Reply #35 on: April 25, 2014, 02:33:36 PM »
Probably, because there are 16^8 integers...
Command: (fix (atof (rtos (/ (- (expt 16. 8) 1) 2))))
2147483647
M.R. on Youtube
« Reply #36 on: April 25, 2014, 04:31:59 PM »
I'm not at my computer (road trip ftw) but my inclination would be to use read, anyone try that?
« Reply #37 on: April 25, 2014, 11:07:22 PM »
Read does not work either.
« Reply #38 on: April 26, 2014, 12:15:14 AM »
How about distof?
« Reply #39 on: April 26, 2014, 08:47:45 AM »
Distof returns the same value as read  :(
« Reply #40 on: April 26, 2014, 09:17:43 AM »
Thanks for trying Ron.
« Reply #41 on: April 26, 2014, 11:16:50 AM »
As discussed previously, I believe the atoi method won't work as the integer conversion functions in AutoLISP are only compatible with 32-bit signed integers and the 64-bit method requires a Long rather than an Int.
This link seems to describe the changes made to the ActiveX API in 2015:
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-6FEDBCCA-91D0-4782-AE5A-49BD4384FD8C
Though, its odd that the setblocktablerecordid method now accepts either a 32-bit integer or a string for 64-bit systems - certainly, this behaviour is not detailed in the documentation.
With these changes in mind, and to retain compatibility with earlier 64-bit systems, I would suggest perhaps:
(defun LM:objectid ( obj )
    (eval
        (list 'defun 'LM:objectid '( obj )
                (   (not (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*"))
                   '(vla-get-objectid obj)
                (   (= 'subr (type vla-get-objectid32))
                   '(vla-get-objectid32 obj)
                (   (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false))
    (LM:objectid obj)
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
But unfortunately I don't have access to a 64-bit system for testing. :(
« Last Edit: April 26, 2014, 11:21:51 AM by Lee Mac »
chlh_jd
« Reply #42 on: April 26, 2014, 03:37:20 PM »
Nice solution , Lee :-)
In my case : In Acad2011 64bit system , Object has two property about ID <ObjectID32> <ObjectID>
                   In Acad2015 64bit system , Object has only one ID <ObjectID>
(defun _ObjectID  (OBJ / ID)
  (vl-catch-all-apply
    (function
      (lambda nil
(setq ID
       (vlax-get
obj
(quote objectid)))))) id)
;;For test
(_ObjectID (vlax-ename->vla-object (car (entsel))))
« Reply #43 on: April 26, 2014, 03:47:06 PM »
Thanks chlh_jd  :-)
If I've understood the API change correctly, the objectid property in 64-bit versions < 2015 (maybe 2014 also?) will return an incorrect object ID, and the objectid32 property must be used instead for these systems.
Could anyone confirm whether the value returned by the objectid property in 64-bit 2015 can be used with the setblocktablerecordid method?
chlh_jd
« Reply #44 on: April 26, 2014, 03:53:37 PM »
I has catch this case sometime in AutoCAD2011 , but didn't know when it come in correct , perhaps I'v update it or .Net Frame .
