Author Topic: Adjust the area of a polygon  (Read 12546 times)
pedroantonio
« on: March 08, 2014, 02:43:49 PM »
Good evening. I am looking for a lisp file that fixes the size polygon.
I designed the polygon knowing the lengths of sides and its area. But  at the end the area is not the same.
Look the attach *.dwg
roy_043
  • BricsCAD 18
Re: Adjust the area of a polygon
« Reply #1 on: March 09, 2014, 03:44:48 AM »
If I look at the green rectangle in your drawing I notice that the long sides are not exactly parallel and one is 165.90 long and the other is 165.93. Both short sides are 30.00. The conclusion must be that this is not an exact rectangle. The question is then: Why is 4977.00 the correct area?
Don't you typically need measurements for multiple diagonals to accurately draw these land parcels?
But in theory you can create a lisp that scales the polyline using this factor:
(sqrt (/ expectedArea currentArea)).
pedroantonio
« Reply #2 on: March 09, 2014, 04:19:08 AM »
the dimensions and the area of ​​the polygon I get from PLANNING.
Yes but if i scale the polygon the dimensions will be change.I don't want to change the dimensions.I need the polygon to have the dimension I give and the area I give.
For example a lisp
1) Select a close polyline
2) Give the area of the polygon
Then adjust the polygon (Keep the dimensions)
Something like mapcheck but with specific area
« Last Edit: March 09, 2014, 04:25:05 AM by Topographer »
snownut2
  • Bricscad 22 Ultimate
« Reply #3 on: March 09, 2014, 10:04:13 AM »
pedro,
You are trying to adjust area by changing polygon angles, with no reference angles to begin with, there can be multiple solutions to this....After looking at your drawing, you realize that by doing this you will be affecting the area of any adjoining lot, you will be opening up pandora's box...
« Last Edit: March 09, 2014, 10:10:54 AM by snownut2 »
pedroantonio
« Reply #4 on: March 09, 2014, 12:35:06 PM »
Yes snownut2 you are right but i was thinking a lisp
3)Select the point  (one or two points to change the angle)
What do you think ? I think this way is better .
snownut2
« Reply #5 on: March 09, 2014, 12:40:50 PM »
Pedro,
Think about that, you need to adjust every single angle to maintain the line lengths, not just one or two.
Bruce
pedroantonio
« Reply #6 on: March 09, 2014, 12:47:50 PM »
Not exactly . If i want to change point 2 ,i need to select point 1 ,point2,point3
look the dwg
snownut2
« Reply #7 on: March 09, 2014, 01:22:12 PM »
Maybe I was a little dramatic when I said every single angle, however I still stand that you need to adjust multiple (many) angles to maintain the line lengths.  (on lots with only a few lot lines it will be all angles).
In your sample drawing, the angle prior to pt1 along with pt1, pt2 & pt3 angles would all be affected by making any area change.
Affecting 4 out of 6 angles, and affecting the area of the abutting lot to the rear.
mailmaverick
« Reply #8 on: March 09, 2014, 01:35:44 PM »
Dear Friend,
I did some research and found that there are multiple solutions to your problem.
There can be multiple combinations of 6 sided polyons with length of sides given by you and area also as given by you.
As an example, I am attaching DWG file in which I have made three 6 sides polygons with each side as given by you and area also as given by you.
You can see that apart from these three, there are even more multiple solutions.
pedroantonio
« Reply #9 on: March 09, 2014, 01:41:42 PM »
yes but if i chose only  one angle to be change  like point1,point2,point3 not all the angles , it will change only the angle in the point 2
roy_043
  • BricsCAD 18
« Reply #10 on: March 09, 2014, 02:02:06 PM »
Isn't this really a case of rounding?
2517.12 ("wrong"); Rounded: 2517 ("correct").
4977.33 ("wrong"); Rounded: 4977 ("correct").
pedroantonio
« Reply #11 on: March 09, 2014, 02:04:15 PM »
yes but in same othe option you will have a bigger difference for example
2517.12 ---->2517.90 or 2519.30 etc
snownut2
« Reply #12 on: March 09, 2014, 02:06:57 PM »
Pedro,
Why don't you try drawing a new lot configuration with a new area by adjusting the angle @ pt2 ONLY, keeping all line lengths are they are then post result here, that way we can understand exactly what it is you are after.
If as in Roy's post it is caused by rounding, instead of using an "=" sign in the comparison statement use  "equal" with a fuzz factor.
  1. (if (equal area1 area2 0.1)
  2.    (carry on)
  3. )
  4.
Bruce
roy_043
  • BricsCAD 18
« Reply #13 on: March 09, 2014, 02:12:30 PM »
(setq differencePercent (* (/ (- 2517.90 2517.0) 2517.0) 100.0)) ; => 0.0357569 percentWhat are we talking about. Aren't these tolerances normal in topography?
pedroantonio
« Reply #14 on: March 09, 2014, 02:33:12 PM »
yes it is. just i ask for it.I understand that is not possible to make a lisp to fix it. Thank you gays..
