Combining both programs:
;; Round Vertices & Show Gaps - Lee Mac
(defun c:round ( / dxf enx idx key lst mod sel tmp vt1 vt2 xc1 )
(setq dxf
("CIRCLE" 10 40)
("LINE" 10 11)
("LWPOLYLINE" 10)
("INSERT" 10)
("POINT" 10)
(if (null *tol*)
(setq *tol* 5.0)
(initget 6)
(if (setq mod (getreal (strcat "\nSpecify rounding tolerance <" (rtos *tol*) ">: ")))
(setq *tol* mod)
(setq mod *tol*)
(if (setq sel (ssget '((0 . "CIRCLE,LINE,LWPOLYLINE,INSERT,POINT"))))
(repeat (setq idx (sslength sel))
(if (setq enx (entget (ssname sel (setq idx (1- idx))))
key (cdr (assoc (cdr (assoc 0 enx)) dxf))
(entmod (rounddxf key mod enx))
(setq enx (entget (ssname sel (setq idx (1- idx)))))
(if (wcmatch (cdr (assoc 0 enx)) "LINE,LWPOLYLINE")
(if (= "LINE" (cdr (assoc 0 enx)))
(setq lst (cons (list (cdr (assoc 10 enx)) (cdr (assoc 11 enx))) lst))
(setq lst (cons (list (cdr (assoc 10 enx)) (cdr (assoc 10 (reverse enx)))) lst))
(setq lst (cons (reverse (car lst)) lst))
(setq lst (vl-sort lst '(lambda ( a b ) (< (caar a) (caar b))))
mod (+ 1e-8 (* mod (sqrt 2.0)))
(while
(setq vt1 (car lst)
xc1 (caar vt1)
lst (cdr lst)
tmp lst
(while (and (setq vt2 (car tmp)) (< (- (caar vt2) xc1) mod))
(and
(< (distance (car vt1) (car vt2)) mod)
(not (equal (car vt1) (car vt2) 1e-10))
(not (equal (car vt1) (cadr vt2) 1e-10))
(entmake
(list
'(00 . "CIRCLE")
'(08 . "Gaps!")
'(62 . 1)
(cons 40 (/ mod 2.0))
(cons 10 (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) (car vt1) (car vt2)))
(setq tmp (cdr tmp))
(defun rounddxf ( key mod lst / rtn )
(foreach itm lst
(if (member (car itm) key)
(setq rtn (cons (cons (car itm) (roundvalue (cdr itm) mod)) rtn))
(setq rtn (cons itm rtn))
(reverse rtn)
(defun roundvalue ( val mod )
(if (listp val)
(mapcar '(lambda ( x ) (round x mod)) val)
(round val mod)
;; Doug Broad
(defun round ( value to )
(setq to (abs to))
(* to (fix (/ ((if (minusp value) - +) value (* to 0.5)) to)))
