Author Topic: Move objects' vertex round of 5  (Read 3753 times)
HasanCAD
« on: February 27, 2014, 09:55:48 AM »
We reciving drawings all objects vertex not drawen in proper way. We draft it again to be round of 5.
Re: Move objects' vertex round of 5
« Reply #1 on: February 27, 2014, 10:01:15 AM »
Why do your x values go from 0 to 120 and 69 to 190?
Here's a quick draft:
(defun c:foo (/ _rnd5 e)
  (defun _rnd5 (n)
    (if   (minusp n)
      (* 5 (fix (- (/ (float n) 5) 0.5)))
      (* 5 (fix (+ (/ (float n) 5) 0.5)))
  (if (setq e (car (entsel "\nPick something: ")))
    (entmod (mapcar '(lambda (x)
             (if (vl-position (car x) '(10 11))
          (append (list (car x)) (mapcar '_rnd5 (cdr x)))
          x
          (entget e '("*"))
« Last Edit: March 02, 2014, 01:39:00 AM by ronjonp »
« Reply #2 on: February 27, 2014, 01:31:32 PM »
Try this program, specifying a rounding tolerance of 5  :-)
HasanCAD
« Reply #3 on: March 02, 2014, 01:12:26 AM »
Thanks ronjonp. I copied the objects 120 to show the deference thats it.
HasanCAD
« Reply #4 on: March 02, 2014, 01:29:47 AM »
Great, Thanks LEE
HasanCAD
« Reply #5 on: March 02, 2014, 01:42:43 AM »
In some cases this habben.
Could the lisp point to the gap if equal 5?
« Reply #6 on: March 02, 2014, 05:44:29 AM »
Great, Thanks LEE
You're welcome  :-)
Try this program:
(defun c:showgaps ( / enx idx lst mod sel tmp vt1 vt2 xc1 )
    (if (null *gap*)
        (setq *gap* 5.0)
    (initget 6)
    (if (setq mod (getreal (strcat "\nShow gaps less than <" (rtos *gap*) ">: ")))
        (setq *gap* mod)
        (setq mod *gap*)
    (if (setq sel (ssget '((0 . "LINE,LWPOLYLINE"))))
            (repeat (setq idx (sslength sel))
                (if (= "LINE" (cdr (assoc 0 (setq enx (entget (ssname sel (setq idx (1- idx))))))))
                    (setq lst (cons (list (cdr (assoc 10 enx)) (cdr (assoc 11 enx))) lst))
                    (setq lst (cons (list (cdr (assoc 10 enx)) (cdr (assoc 10 (reverse enx)))) lst))
                (setq lst (cons (reverse (car lst)) lst))
            (setq lst (vl-sort lst '(lambda ( a b ) (< (caar a) (caar b)))))
            (while
                (setq vt1 (car  lst)
                      xc1 (caar vt1)
                      lst (cdr  lst)
                      tmp lst
                (while (and (setq vt2 (car tmp)) (< (- (caar vt2) xc1) mod))
                            (< (distance (car vt1) (car  vt2)) mod)
                            (not (equal  (car vt1) (car  vt2) 1e-10))
                            (not (equal  (car vt1) (cadr vt2) 1e-10))
                        (entmake
                            (list
                               '(00 . "CIRCLE")
                               '(08 . "Gaps!")
                               '(62 . 1)
                                (cons 40 (/ mod 2.0))
                                (cons 10 (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) (car vt1) (car vt2)))
                    (setq tmp (cdr tmp))
If rounding to a tolerance of 5.0, you will need to show gaps less than or equal to 5*sqrt(2) i.e. 7.07
« Last Edit: March 02, 2014, 05:47:52 AM by Lee Mac »
HasanCAD
« Reply #7 on: March 02, 2014, 10:13:34 AM »
I am trying to compine both of them in one lisp
But how to extract root of number?
(setq mod (+ (* m m) (* m m)))
Edit:
Is it correct?
(setq m 5.)
(setq mod (sqrt (+ (* m m) (* m m))))
« Last Edit: March 02, 2014, 12:30:44 PM by HasanCAD »
« Reply #8 on: March 02, 2014, 12:29:39 PM »
Combining both programs:
;; Round Vertices & Show Gaps  -  Lee Mac
(defun c:round ( / dxf enx idx key lst mod sel tmp vt1 vt2 xc1 )
    (setq dxf
            ("CIRCLE"     10 40)
            ("LINE"       10 11)
            ("LWPOLYLINE" 10)
            ("INSERT"     10)
            ("POINT"      10)
    (if (null *tol*)
        (setq *tol* 5.0)
    (initget 6)
    (if (setq mod (getreal (strcat "\nSpecify rounding tolerance <" (rtos *tol*) ">: ")))
        (setq *tol* mod)
        (setq mod *tol*)
    (if (setq sel (ssget '((0 . "CIRCLE,LINE,LWPOLYLINE,INSERT,POINT"))))
                (if (setq enx (entget (ssname sel (setq idx (1- idx))))
                          key (cdr (assoc (cdr (assoc 0 enx)) dxf))
                    (entmod (rounddxf key mod enx))
                (if (wcmatch (cdr (assoc 0 enx)) "LINE,LWPOLYLINE")
                        (if (= "LINE" (cdr (assoc 0 enx)))
                  mod (+ 1e-8 (* mod (sqrt 2.0)))
            (while
                (setq vt1 (car  lst)
                      xc1 (caar vt1)
                      lst (cdr  lst)
                      tmp lst
                        (entmake
                            (list
                               '(00 . "CIRCLE")
                               '(08 . "Gaps!")
                               '(62 . 1)
(defun rounddxf ( key mod lst / rtn )
    (foreach itm lst
        (if (member (car itm) key)
            (setq rtn (cons (cons (car itm) (roundvalue (cdr itm) mod)) rtn))
            (setq rtn (cons itm rtn))
    (reverse rtn)
(defun roundvalue ( val mod )
    (if (listp val)
        (mapcar '(lambda ( x ) (round x mod)) val)
        (round val mod)
;; Doug Broad
(defun round ( value to )
    (setq to (abs to))
    (* to (fix (/ ((if (minusp value) - +) value (* to 0.5)) to)))
HasanCAD
« Reply #9 on: March 03, 2014, 05:59:34 AM »
Thanks LEE
« Reply #10 on: March 04, 2014, 05:04:17 PM »
