Author Topic: Change the insert units from Inch to Millimeter  (Read 2257 times)
Coder
« on: February 25, 2014, 05:56:52 AM »
Hello guys .
Is there a way to change the property ( Block Unit ) for many blocks from Inch to Millimeter ?
Many thanks in advance . :-)
irneb
Re: Change the insert units from Inch to Millimeter
« Reply #1 on: February 25, 2014, 06:36:59 AM »
DXF-wise (i.e. no ActiveX) you'd entmod the BlockRecord's 70 code: http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-A1FD1934-7EF5-4D35-A4B0-F8AE54A9A20A.htm,topicNumber=d30e675444
It uses the same value as the InsUnits sysvar: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-4f8f.htm,topicNumber=d0e348840
So you'd be changing it from 1 to 4.
If you go the ActiveX route, then you can step through the active document's blocks collection. And set each of those Block definition objects' Units property:
http://entercad.ru/acadauto.en/index.html?page=idh_units.htm
Just take note that any inserts already placed might need to be scaled after this.
Coder
« Reply #2 on: February 25, 2014, 07:09:29 AM »
Thank you so much , that 's great
I solved the problem :-) .
irneb
« Reply #3 on: February 25, 2014, 08:10:53 AM »
Glad to help!
ChrisCarlson
« Reply #4 on: February 25, 2014, 08:12:35 AM »
When you change your block's units, are you changing their size since now they are 25.4x smaller?
Coder
« Reply #5 on: February 25, 2014, 08:33:12 AM »
I copied and pasted block from one drawing to another and when I tried to insert one of these blocks I realized the big size of the block and closed the drawing without saving , after that I resized the block to millimeters with the help of Mr irneb and recopied and pasted the blocks again and it works great now .  :-)
Thank you .
