Author Topic: Find all characters in a SHX file?  (Read 4738 times)
Peter2
« on: January 30, 2014, 09:44:24 AM »
Is there a way in (V)Lisp to find all characters which are defined in a SHX file? I need a list like "A, B, C" or better Ascii-codes or Unicode-definitions like "\u+1234".
Peter
BricsCAD V23
David Bethel
Re: Find all characters in a SHX file?
« Reply #1 on: January 30, 2014, 11:43:45 AM »
If you covert the shx file back into a shp file it would be very easy.
SHX2SHP.EXE used to be included in the core ACAD install.  I don't know if it still is
With a little digging you should able to find the shapefile ( .shp ) format.
I take a look see myself as to what is out there.
-David
R12 Dos - A2K
David Bethel
« Reply #2 on: January 30, 2014, 11:59:40 AM »
Starting with Page 117
http://docs.autodesk.com/ACDMAC/2013/ENU/PDFs/acdmac_2013_customization_guide.pdf
I have 6 copies of SHX2SHP.EXE on this machine.  They are all the same file, just different locations
     Disk Volume:                           1-30-14  11:51:28 am   Page 1
                      Available space    207,271,845,888 bytes
              583,261 logged files using 338,111,105,903 bytes
                    6 tagged files using          90,132 bytes
      Path: C:\ACAD\FONTS
                    1 tagged files using          15,022 bytes
 6-17-95   8:56:18 pm      15,022 .a.. SHX2SHP .EXE
      Path: C:\ACAD\UT
      Path: C:\Documents and Settings\Public\acad\FONTS
      Path: C:\Documents and Settings\Public\acad\UT
      Path: C:\Users\Public\acad\FONTS
      Path: C:\Users\Public\acad\UT
I'll take credit for (2) of these, the rest were installed by ACAD somewhere along the line.
-David
R12 Dos - A2K
Peter2
« Reply #3 on: January 30, 2014, 12:14:14 PM »
If you covert the shx file back into a shp file it would be very easy.....
Thanks, but the idea is to create a kind of simple SHX Viewer inside AutoCAD. The software should
a) find all defined characters in a defined SHX
b) create a TEXT in AutoCAD for each character
b) is simple, a) is what I'm asking for.
Peter
BricsCAD V23
David Bethel
« Reply #4 on: January 30, 2014, 01:02:44 PM »
Doing viewer is very simple.  However it will not inform you as to what is defined or not.  AutoCAD will simply display a question mark for unknown characters.
You will have to go back to the original shape file definitions.  -David
R12 Dos - A2K
Peter2
« Reply #5 on: January 30, 2014, 02:33:27 PM »
...However it will not inform you as to what is defined or not....
That's the problem. A font which uses some special characters at ANSI Code 8000 or 10000 creates a lot of trash if I print thousands of question marks.
Peter
BricsCAD V23
David Bethel
« Reply #6 on: January 31, 2014, 06:11:06 AM »
You will have to test for BIGFONTS, SHAPE formatted files and whether the shape_number is either HEX or Decimal
This could be the base engine :
  1. (defun c:findchr (/ file rf nl c f fd hl)
  2.    (while (not file)
  3.           (setq file
  4.              (getfiled "Shape File to Read"
  5.                        (if shp_file shp_file "/acad/fonts/")  "shp" 2)))
  6.   (setq shp_file file)
  7.   (setq hl nil)
  8.   (setq rf (open file "r"))
  9.   (while (setq nl (read-line rf))
  10.          (cond ((= "*0,4," (substr nl 1 5))
  11.                 (setq fd (substr nl 6)))
  12.                ((= "*"   (substr nl 1 1))
  13.                 (setq c 3 f nil)
  14.                 (while (and (not f)
  15.                             (< c (- (strlen nl) 3)))
  16.                        (if (= "," (substr nl c 1))
  17.                            (setq f T
  18.                                  hl (cons (substr nl 2 (- c 2)) hl)))
  19.                        (setq c (1+ c))))))
  20.   (close rf)
  21.   (princ (strcat "\n" (rtos (length hl) 2 0) " Characters Found In " file ", " fd))
  22.   (prin1))
  23.
The list hl contains the shape_numbers of the characters defined in the selected .shp file.
-David
« Last Edit: January 31, 2014, 08:12:12 AM by David Bethel »
R12 Dos - A2K
irneb
« Reply #7 on: February 01, 2014, 10:13:48 AM »
You could always use findfile to check if there's already a SHP file with the same name as the SHX. Then if not found use startapp function to run the SHX2SHP on the SHX file to create a SHP. Then use something like David's code to figure out which characters / shapes are defined in that font/shape file.
