Author Topic: Chamfering code!Thanks for any help!  (Read 2575 times)
flyfox1047
« on: January 28, 2014, 07:57:21 AM »
(defun c:dj ()
        (setq height 2.5)
(if (setq judge (getreal "Input text height(Default 2.5)"))
     (setq height judge)
        (setq messege (entsel))
        (setq ent (entget (car messege)))
(setq select_point (cadr messege))
(if (equal (cdr (assoc 0 ent)) "LINE" )
    (setq daojiao (chfd ))
   (setq daojiao (reduce ent select_point))
;(princ daojiao)
(setq point_x (car (caddr daojiao)) point_y (cadr (caddr daojiao))  x1 (car point_x) y1
(cadr point_x) x2 (car point_y) y2 (cadr point_y))
(setq le_point (list (* 0.5 (+ x1 x2)) (* 0.5 (+ y1 y2)) ))
        (setq c1 (car daojiao) c2 (cadr daojiao))
(if (= (rtos c1 2 1) (rtos c2 2 1))
    (setq c (strcat "C" (rtos c1 2 1)))
(setq c (strcat (rtos c1 2 1) "*" (rtos c2 2 1) ))
(princ c)
(princ le_point)
(princ height)
        (bz c le_point height)
        ;(command "leader"  le_point pause pause "" "" "n")
;(setq ent (entget (entlast)))
;(le ent c height)
(defun bz (txt1 p height / *error* name1 name2 name3)
  (defun *error* (msg) ;
    (entdel name1) (entdel name2) (if name3 (entdel name3))
    (princ "err: ")(princ msg)
  (setq ty (getvar "TEXTSTYLE") kd3 0)
  (setq kd1 (caadr (textbox (list '(0 . "text")(cons 1 txt1)(cons 40 height)(cons 41 0.7)(cons 7 ty)))))
  (setq kd2 (caadr (textbox (list '(0 . "text")(cons 1 "lyt love lhl")(cons 40 height)(cons 41 0.7)(cons 7 ty)))))
  (setq kd (max kd1 kd2) kd (+ kd 50))
  ;(setq p (getpoint "\nSpecify the basis points:"))
  (setq pd t)
  (while pd
    (setq gr (grread t 4 1) mode (car gr) pt (cadr gr))
    (if (= kd3 0) (setq kd kd1))
    (if (and (listp pt) (>= (car pt) (car p))) (progn
      (setq p0 (polar pt 0 kd))
      (setq p1 (polar pt 0 (/ (- kd kd1) 2)) p1 (polar p1 (angtof "90") (* 0.2 height)))
      (setq p2 (polar pt 0 (/ (- kd kd2) 2)) p2 (polar p2 (angtof "270") 350)))
    (if (and (listp pt) (< (car pt) (car p))) (progn
      (setq p0 (polar pt pi kd))
      (setq p1 (polar p0 0 (/ (- kd kd1) 2)) p1 (polar p1 (angtof "90") (* 0.2 height)))
      (setq p2 (polar p0 0 (/ (- kd kd2) 2)) p2 (polar p2 (angtof "270") 350)))
    (if (= mode 5) (progn
      (if name1 (entdel name1))
      (entmake (list '(0 . "LWPOLYLINE")'(100 . "AcDbEntity")'(100 . "AcDbPolyline")'(90 . 3)
        (cons 10 p)(cons 10 pt)(cons 10 p0)))
      (setq name1 (entlast))
      (if name2 (entdel name2))
      (entmake (list '(0 . "text")(cons 1 txt1)(cons 40 height)(cons 41 0.7)(cons 10 p1)(cons 7 ty)))
      (setq name2 (entlast))
      (if (= kd3 1) (entmake (list '(0 . "text")(cons 1 txt2)(cons 40 height)(cons 41 0.7)(cons 10 p2)(cons 7 ty))))
      (if (= kd3 1) (setq name3 (entlast))))
    (if (= mode 3) (setq pd nil))
    (if (or (= mode 2) (= mode 25)) (progn (setq pd nil) (entdel name1) (entdel name2) (if name3 (entdel
name3))))
(defun le (ent choice height)
        (setq points '())
    (mapcar '(lambda (x)
                                 ((= 10 (car x)) (setq points (cons (cdr x) points)))
   ent
    (setq point_end   (car  points))
    (setq point_start (cadr points))
    (if (> (- (car point_end) (car point_start)) 0)
           (setq point (list (+ (car point_end)  (* 0.7 height)) (- (cadr point_end) (* 0.5
height))))
               (command "text" point height 0 choice )
           (setq point (list (- (car point_end) (* 0.7 height) ) (- (cadr point_end) (* 0.5
height))))
                   (setq entname (entlast))
           (setq ent (entget entname))
           (entmod
                 (mapcar '(lambda ( x)
                                      ((= (car x) 72) (cons (car x)  2))
              ((= (car x)
11) (cons (car x)  point))
              (t x)
                       ent
        (setq text_point (mapcar '* (mapcar '+ point_end point_start) '(0.5 0.5 0.5)))
(setq height_modify  (list 0 (* 0.2 height) 0 ) )
(setq text_point (mapcar '+  text_point height_modify))
(entmod
                                      ((= (car x) 72) (cons (car x)  1))
              ((= (car x)
11) (cons (car x)  text_point))
              (t x)
                       ent
(defun reduce (ent select_point / daojiao1 point0 point1 point2 point3 x y x1 x2 y1 y2)
        (setq points '())
(setq i 1)
(setq x (car select_point) y (cadr select_point))
        (mapcar '(lambda (x)  (cond
                                      ((= 10 (car x))  (setq points (cons (cdr x) points)) )
ent
    (setq add_point1 (car points))
(setq add_point2 (cadr points))
(setq points (reverse points))
(setq add_point3 (car points))
(setq points (cons add_point1 points))
(setq points (cons add_point2 points))
(setq points (cons add_point3 points))
(while (< i (- (length points) 2) )
       (setq point1 (nth i points))
   (setq point2 (nth (+ i 1) points))
   (setq x1 (car point1) y1 (cadr point1) x2 (car point2) y2 (cadr point2))
   (if (and (or (and (< x x1) (> x x2)) (and (< x x2) (> x x1))) (or (and (< y y1) (>
y y2)) (and (< y y2) (> y y1))))
       (setq j i i (length points))
   (setq i (+ i 1))
(setq point0 (nth (- j 1) points) point3 (nth (+ j 2) points))
(setq default_color (getvar "cecolor"))
(command "color" 1 "")
(command "line" point0 point1 "")
(setq ent1 (entlast))
(command "line" point1 point2 "")
(setq ent2 (entlast))
(command "line" point2 point3 "")
(setq ent3 (entlast))
(setq daojiao1 (chfd))
(entdel ent1 )
(entdel ent2 )
(entdel ent3 )
(command "color" default_color "")
(setq daojiao1 daojiao1)
(defun chfd (/ _dxf _para _valid a typ obj p1 p2 intrpt)
(Defun _dxf (e dx) (cdr (assoc dx (entget e))))
(defun _para (o p)
    (vlax-curve-getparamatpoint
      o
      (vlax-curve-getClosestPointTo o p )
(defun _valid   (e typ / e)
      (if (wcmatch (Setq v (_dxf e 0)) typ)
            v))
      (if (and (setq a (entsel "\nSelect Chamfered segment: "))
               (Setq typ (_valid (setq obj (car a))
                                 "LWPOLYLINE,LINE")))
(if (eq typ "LINE")
      (command "change" obj "" "p" "c" 3 "")
                          (while (not (And
                                            (setq obj2 (car  (entsel  "\nSelect another segment: ")))
(not (command "change" obj2 "" "p" "c" 3 ""))
                                            (setq obj3 (car  (entsel  "\nAnd another: ")))
(not (command "change" obj3 "" "p" "c" 3 ""))
                                            (_valid obj2 "LINE")
                                            (_valid obj3 "LINE"))
                          (setq intrpt (inters (_dxf obj2 10)
                                               (_dxf obj2 11)
                                               (_dxf obj3 10)
                                               (_dxf obj3 11)
                                               nil))
                          (Setq p1 (_dxf obj 10) p2 (_dxf obj 11))
                              (setq prm1 (_para obj (cadr a)))
(setq pts (mapcar 'cdr
                  (vl-remove-if-not
                        '(lambda (k)
                               (= (car k) 10)
                        (entget obj)
  (setq inbetween (vl-some '(lambda (j k)
  (if (< (_para obj j) prm1 (_para obj k))
    (list j k)
       pts
       (cdr pts)
                        (and
(setq p1 (cadr (member (car inbetween) (reverse pts))))
(setq p2 (cadr (member (Cadr inbetween) pts)))
(setq intrpt (inters p1  (Car inbetween)
       p2  (cadr inbetween) nil)
                                (setq p1 (Car inbetween) p2 (cadr inbetween))
                    )(princ "\nNull/Invalid selection")
          (if intrpt
                  (print (strcat "<<< "
(rtos (distance p1 intrpt) 2 2)
"x"
(rtos (distance p2 intrpt) 2 2)
  )(princ "\nInvalid data")
(setq aa (distance p1 intrpt))
(setq bb (distance p2 intrpt))
(list aa bb (list p1 p2))
Above is my code,Always feel is not perfect!more pick...
This code by pBe ,I Feel Fine ,Part of the calculation of chamfer
(defun c:chfd (/ _dxf _para _valid a typ obj p1 p2 intrpt)
(defun _para (o p)
      o
      (vlax-curve-getClosestPointTo o p)
            v))
(if (eq typ "LINE")
                          (while (not (And
                                               (_dxf obj2 11)
                                               (_dxf obj3 10)
                                               (_dxf obj3 11)
                                               nil))
                  (vl-remove-if-not
                        '(lambda (k)
                               (= (car k) 10)
                        (entget obj)
    (list j k)
       pts
       (cdr pts)
                        (and
          (if intrpt
"x"
              )(princ)
I want to dynamic drag and drop,like DILEADER:
I know that "DILEADER'' , Very complicated code,capacity-constrained!I hope someone could help me to finish it with pBe's code.
« Last Edit: January 28, 2014, 08:34:40 AM by flyfox1047 »
Re: Chamfering code!Thanks for any help!
« Reply #1 on: January 28, 2014, 10:53:41 AM »
Here is a simple example to give you some ideas.
(defun c:foo (/ _activespace e gr ml p1 p2)
  (defun _activespace (/ doc)
    (setq doc (vla-get-activedocument (vlax-get-acad-object)))
    (if (= (getvar 'cvport) 1)
      (vla-get-paperspace doc)
      (vla-get-modelspace doc)
    (and (setq e (car (entsel)))
(wcmatch (cdr (assoc 0 (entget e))) "LWPOLYLINE,LINE")
(setq ml (vlax-invoke (_activespace) 'addmleader (append '(0. 0. 0.) (getvar 'viewctr)) 0))
     (progn (vla-put-textstring ml "hello")
    (while (= 5 (car (setq gr (grread 't 13 2))))
      (redraw)
      (grdraw (setq p1 (cadr gr)) (setq p2 (vlax-curve-getclosestpointto e (cadr gr))) 2)
      (vlax-invoke ml 'setleaderlinevertices 0 (apply 'append (list p2 p1)))
snownut2
  • Bricscad 22 Ultimate
« Reply #2 on: January 28, 2014, 04:35:59 PM »
ronjonp,
If you saw how this subject (identical thread) and the previous thread was going @ Cad Tutor, you would see that suggestions are not enough.....
Seems the idea of attempting to create something from others advise/suggestions is not what is being sought.
« Reply #3 on: January 28, 2014, 08:09:11 PM »
ronjonp,
Good to know .. I respectfully bow out ;).
ribarm
  • Marko Ribar, architect
« Reply #4 on: January 29, 2014, 09:07:00 AM »
Flyfox, can't you just use "move" command after you create leader?
M.R. on Youtube
flyfox1047
« Reply #5 on: January 30, 2014, 02:01:19 AM »
Thanks my friend!, thanks !ronjonp, pBe help me to solve this problem!
