Author Topic: converting splines into best fit lines and arcs to withing a certain tolerance?  (Read 4317 times)
Bob Q
I saw there was someone working on routine back in 2004, just wondering if there have been any nice routines created that will do a Spline to best fit lines and arcs?
I had one years ago in the era of 2000, but lost it! Ha!
Looking through my collections I have:
;;CADALYST 12/03 AutoLISP Solutions  SPLINE-TO-PLINE.LSP
;;(c) 2003 Tony Hotchkiss
(defun spline-to-pline (/ i)
;;;CADALYST 01/06  Tip 2082: Spline2Pline2.lsp     Spline to Polyline Conversion - Update     (c) 2006 Cadalyst and Lloyd Beachy + narrator
;; Spline2Pline2.lsp (c) 2005 Lloyd Beachy + narrator
;; Routine to convert splines to plines
(Defun C:S2P2 (/ ss pt# cmdecho osmode clayer count ent lay lng pt-list cnt)
7/29/2004
;|Try this snippet. What it does is step through the given spline at a given tolerance
distance and pull a point off of the curve. It then adds that point to a running list.
The snippet returns that list of points that you could then use to build your polyline.
(defun Spline->Pline
GP
  • Vercelli, Italy
Try FLATTEN (the best).
Bob Q
Any chance I could get a copy of those couple routines?
Thanks!
Bob Q
I tried flatten, and the attached image shows what it does. It seems to convert everything into lines, making the radiuses really jaged.
What about using PEDIT?
Bob Q
You get a similar situation, all lines, no best fit arcs.
gile
  • Marseille, France
Hi
Look at the PLINECONVERTMODE sysvar.
Bob Q
Hi
o.k. cool! I will check it out!
Wow that was drawn using a spline?  :o
Bob Q
It was a nice smooth spline, the result was after running flatten...
