Author Topic: Pline jig with double  (Read 3164 times)
krkec
« on: December 31, 2013, 09:25:07 AM »
hi
I want to modify Kean Walmsely polyline Jig. For before every point user will be asked for entering double and this double will be subtacted form points y value.
Here is class code;
using System;
using System.Linq;
using System.Text;
namespace prolazi
    class PlineJig : EntityJig
        // Maintain a list of vertices...
        // Not strictly necessary, as these will be stored in the
        // polyline, but will not adversely impact performance
        Point3dCollection m_pts;
        // Use a separate variable for the most recent point...
        // Again, not strictly necessary, but easier to reference
        Point3d m_tempPoint;
        Plane m_plane;
        double nadsloj = 1;
        double cent;
        double promjerC = 300;
        public PlineJig(Matrix3d ucs)
            : base(new Polyline())
            // Create a point collection to store our vertices
            m_pts = new Point3dCollection();
            // Create a temporary plane, to help with calcs
            Point3d origin = new Point3d(0, 0, 0);
            Vector3d normal = new Vector3d(0, 0, 1);
            normal = normal.TransformBy(ucs);
            m_plane = new Plane(origin, normal);
            // Create polyline, set defaults, add dummy vertex
            Polyline pline = Entity as Polyline;
            pline.SetDatabaseDefaults();
            pline.Normal = normal;
            pline.AddVertexAt(0, new Point2d(0, 0), 0, 0, 0);
        protected override SamplerStatus Sampler(JigPrompts prompts)
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            JigPromptPointOptions jigOpts =
              new JigPromptPointOptions();
            jigOpts.UserInputControls =
              (UserInputControls.Accept3dCoordinates |
              UserInputControls.NullResponseAccepted |
              UserInputControls.NoNegativeResponseAccepted
            //JigPromptOptions jpo = new JigPromptOptions();
            if (m_pts.Count == 0)
                // For the first vertex, just ask for the point
                jigOpts.Message =
                  "\nStart point of polyline: ";
            else if (m_pts.Count > 0)
                //cent = funkcije.odnadsloj(nadsloj) + promjerC * 0.0005;
                // For subsequent vertices, use a base point
                jigOpts.BasePoint = m_pts[m_pts.Count - 1];
                jigOpts.UseBasePoint = true;
                jigOpts.Message = "\nPolyline vertex: ";
            else // should never happen
                return SamplerStatus.Cancel;
            // Get the point itself
            PromptPointResult res =
              prompts.AcquirePoint(jigOpts);
            // Check if it has changed or not
            // (reduces flicker)
            if (m_tempPoint == res.Value)
                return SamplerStatus.NoChange;
            else if (res.Status == PromptStatus.OK)
                m_tempPoint = res.Value;
                //m_tempPoint = new Point3d(res.Value.X, res.Value.Y - cent, 0);
                return SamplerStatus.OK;
        protected override bool Update()
            // Update the dummy vertex to be our
            // 3D point projected onto our plane
            pline.SetPointAt(
              pline.NumberOfVertices - 1,
              m_tempPoint.Convert2d(m_plane)
            return true;
        public Entity GetEntity()
            return Entity;
        public void AddLatestVertex()
            Point3d k = new Point3d(m_tempPoint.X, m_tempPoint.Y - cent, 0);
           //_tempPoint = k;
            m_pts.Add(k);
            // Create a new dummy vertex...
            // can have any initial value
            pline.AddVertexAt(
              pline.NumberOfVertices,
              new Point2d(0, 0),
              0, 0, 0
        public void RemoveLastVertex()
            // Let's remove our dummy vertex
            pline.RemoveVertexAt(m_pts.Count);
Here is function code:
[CommandMethod("MYPOLY")]
        public void MyPolyJig()
            Document doc =
            // Get the current UCS, to pass to the Jig
            Matrix3d ucs =
              ed.CurrentUserCoordinateSystem;
            // Create our Jig object
            PlineJig jig = new PlineJig(ucs);
            // Loop to set the vertices directly on the polyline
            bool bSuccess = true, bComplete = false;
            do
                PromptResult res = ed.Drag(jig);
                bSuccess =
                  (res.Status == PromptStatus.OK);
                // A new point was added
                if (bSuccess)
                    jig.AddLatestVertex();
                // Null input terminates the command
                bComplete =
                  (res.Status == PromptStatus.None);
                if (bComplete)
                    // Let's clean-up the polyline before adding it
                    jig.RemoveLastVertex();
            } while (bSuccess && !bComplete);
            // If the jig completed successfully, add the polyline
            if (bComplete)
                // Append entity
                Transaction tr =
                  db.TransactionManager.StartTransaction();
                using (tr)
                    BlockTable bt =
                      (BlockTable)tr.GetObject(
                        db.BlockTableId,
                        OpenMode.ForRead,
                        false
                    BlockTableRecord btr =
                      (BlockTableRecord)tr.GetObject(
                        bt[BlockTableRecord.ModelSpace],
                        OpenMode.ForWrite,
                        false
                    btr.AppendEntity(jig.GetEntity());
                    tr.AddNewlyCreatedDBObject(jig.GetEntity(), true);
                    tr.Commit();
I tried everyting please help.
Re: Pline jig with double
« Reply #1 on: February 02, 2017, 10:58:21 AM »
I reckon that this one stumped all the readers.... 3+ year old post, read 428 times, not one response. When I found this in a search I was hopeful of locating an answer to a very similar question I have. Actually, it's pretty much identical, wherein I need to prompt the user for an elevation after a point is successfully picked by the user. I have the Jig working as I need, complete with similar options allowed by the ACAD Polyline command, but I need to store the vertices of the polyline, including user entered Z values, for creating a Civil3D featureline (which is essentially a 3dpoly with arcs) from the polyline. Hoping a bump here will stir some interest...
huiz
  • Certified Prof C3D
« Reply #2 on: February 02, 2017, 03:15:39 PM »
I think you should keep a List<double> for the Z-values next to the Jig polyline and afterwards create the Feature Line with the vertices and bulges combined with the doubles.
« Reply #3 on: February 02, 2017, 03:44:40 PM »
Right, Huiz, but, how to get the doubles for the Z as the user selects a point? I think the Jig needs to be stopped/paused, get the double, resume the Jig. I'm just not coming up with the How to do that.
Atook
  • AKA Tim
« Reply #4 on: February 02, 2017, 04:30:12 PM »
Can you just drop something in the SamplerStatus Override?
Like this?
Code - C#: [Select]
  1. protected override SamplerStatus Sampler(JigPrompts prompts)
  2. {
  3.         PromptPointResult ppResult;
  4.                 JigPromptPointOptions jigOpts = new JigPromptPointOptions
  5.                 {
  6.                         UserInputControls = UserInputControls.NullResponseAccepted,
  7.                 };
  8.                 ppResult = prompts.AcquirePoint(jigOpts);
  9.                 if (ppResult.Status==PromptStatus.Keyword)
  10.                 else if (ppResult.Status==PromptStatus.OK)
  11.                 {
  12.                         if (ppResult.Value.DistanceTo(LastPoint) < 0.1)
  13.                         {
  14.                                 return SamplerStatus.NoChange;
  15.                         }
  16.                         // get us an ELEVATION, YEAH!
  17.                         PromptDoubleResult pdr = Active.Editor.GetDouble("Enter Elevation: ");
  18.                         double z = 0;
  19.                         if (pdr.Status==PromptStatus.OK)
  20.                         {
  21.                                 LastPoint = ppResult.Value;
  22.                                 z = pdr.Value;
  23.                                 // do something cool here
  24.                         }
  25.                 }
  26.         }
  27. }
  28.
  29.
« Reply #5 on: February 02, 2017, 06:20:40 PM »
Atook, thanks but I don't think it's that simple. The ppResult.Status = OK every time the cursor moves. I only want to get the elevation from the user when they Pick a point.
ANd as I was typing this I realized I need to do this in the code which calls the ed.Drag() when that Result is OK. Will report back with what I find... Thanks!
Atook
  • AKA Tim
« Reply #6 on: February 02, 2017, 10:00:38 PM »
Hmm... I thought ppr only returned when the user clicks, I'll have to look at the complete implementation of my jig.
That code is pulled from I jig I use that prompts the user for an angle after they click to insert a block. I may have simplified it too much for this post.
Curious to see what you come up with.
« Reply #7 on: February 03, 2017, 12:23:11 PM »
OK, this is now working as I had hoped. I have a global Point3dCollection, _vertices, that I add each polyline vertex created with the user entered elevation. It is much simpler than I had thought it would be (as usual, it seems).
Code - C#: [Select]
  1. //portion of the command code which constructs and calls the Jig
  2.             while (true)
  3.             {
  4.                 PromptResult res = ed.Drag(jig);
  5.                 switch (res.Status)
  6.                 {
  7.                     // New point was added, keep going
  8.                     case PromptStatus.OK:
  9.                         jig.AddDummyVertex();
  10.                         _vertices.Add(getElevatedPoint(ed, jig._tempPoint)); //<<<<Added this line, had to set the _tempPoint to public in the jig class
  11.                         break;
  12.
  13.                     // Keyword was entered
  14.                     case PromptStatus.Keyword:
  15. //remainder of code unchanged from Kean's example
  16.
The getElevatedPoint function handles the ed.GetDouble(), and has options as well to set by elevation/grade/slope/difference, with the end result being the elevated point for use later with the featureline.
« Reply #8 on: February 03, 2017, 01:22:52 PM »
ARGHHH. So I hadn't noticed that the jig disappears while it is asking for the elevation...now to figure out why that is.
« Reply #9 on: February 03, 2017, 02:16:33 PM »
I've got one that automatically fillets polyline as you draw it and had to drop the jig and just did it with prompting and using Editor.Command.
If you like I can dig it up and post it.
« Reply #10 on: February 03, 2017, 02:59:53 PM »
Thanks Jeff, I got it sorted out. While I'm asking for the user to enter the elevation I create a TransientGraphic of the Jig's Entity, then dispose of it when it goes back to jigging.. This keeps the polyline on the screen at all times.
