Author Topic: Range Function  (Read 9956 times)
LE3
Re: Range Function
« Reply #15 on: November 17, 2013, 12:06:42 PM »
Have you seen the work of Sergey Bochkanov ALGLIB Project --- for the LMA - give it a read/try:
http://www.alglib.net/optimization/levenbergmarquardt.php
ymg
Re: Range Function
« Reply #16 on: November 17, 2013, 12:19:56 PM »
Thanks Luis,
Yes I did see it and it is well done.
Right now concentrating to get something going, so I am translating that Python implementation.
After that with help from the gurus here maybe optimize it and then includes those nice to have like
so called  geodesic acceleration etc.
But we are in the wrong thread.
ymg
ymg
Re: Range Function
« Reply #17 on: November 18, 2013, 01:51:36 AM »
Here is the latest, using Cab's offering with a little modification.
Mind you we still have a divide by zero error if step is set at zero,
may be we should wrap the function with a cond.
Also get a bad return at (in_range 0 10 3), so maybe the logic behind subtracting 1 from (fix (/ (- end start) step))
is not correct.
ymg
  1. (defun in_range (start end step / value)
  2.   (setq value (list start))
  3.     (repeat (- (fix (/ (- end start) step)) 1)
  4.       (setq value (cons (setq start (+ step start)) value))
  5.     )
  6.   )
  7. )
  8.
So we modify like so:
  3.   (repeat (fix (/ (- end start) step))
  5.   )
  6.   (reverse (if (= (car value) end) (cdr value) value))
  7. )
  8.
Returns from autolisp/ python:
  1. $ (in_range 0 10 1)
  2.    (0 1 2 3 4 5 6 7 8 9)
  3. >>> range(10)
  4. [0, 1, 2, 3, 4, 5, 6, 7, 8, 9]
  5.
  6. $ (in_range 1 11 1)
  7. (1 2 3 4 5 6 7 8 9 10)
  8. >>> range(1, 11)
  9. [1, 2, 3, 4, 5, 6, 7, 8, 9, 10]
  10.
  11. $ (in_range 0 30 5)
  12. (0 5 10 15 20 25)
  13. >>> range(0, 30, 5)
  14. [0, 5, 10, 15, 20, 25]
  15.
  16. $ (in_range 0 10 3)
  17. (0 3 6 9)
  18. >>> range(0, 10, 3)
  19. [0, 3, 6, 9]
  20.
  21. $ (in_range 0 -10 -1)
  22. (0 -1 -2 -3 -4 -5 -6 -7 -8 -9)
  23. >>> range(0, -10, -1)
  24. [0, -1, -2, -3, -4, -5, -6, -7, -8, -9]
  25.
  26. $ (in_range 0 0 1)
  27. nil
  28. >>> range(0)
  29. []
  30. >>> range(1, 0)
  31. []
  32.
  33.
« Last Edit: November 18, 2013, 03:06:35 AM by ymg »
ElpanovEvgeniy
  • Moscow (Russia)
Re: Range Function
« Reply #18 on: November 18, 2013, 02:58:58 AM »
recursion way
  1. (defun range (s e i)
  2.   (if (< s e)
  3.     (cons s (range (+ i s) e i))
  4.   )
  5. )
ymg
Re: Range Function
« Reply #19 on: November 18, 2013, 03:12:21 AM »
recursion way
Best one!!! by a tall margin.
ymg
ElpanovEvgeniy
  • Moscow (Russia)
Re: Range Function
« Reply #20 on: November 18, 2013, 03:16:31 AM »
recursion way
ymg
Thank you!
roy_043
  • BricsCAD 18
Re: Range Function
« Reply #21 on: November 18, 2013, 04:24:31 AM »
@ ElpanovEvgeniy:
Your function is nice and short but:
(EE_range 0 -10 -1) => nil
ymg
Re: Range Function
« Reply #22 on: November 18, 2013, 04:44:13 AM »
@ ElpanovEvgeniy:
Ooops! ,  So then we have:
  1. ;;  By Cab      (iterative)                                                   ;
  2. ;;        ;
  3. (defun in_range (start end step / value)
  4.   (setq value (list start))
  5.   (repeat (fix (/ (- end start) step))
  6.      (setq value (cons (setq start (+ step start)) value))
  7.   )
  8.   (reverse (if (= (car value) end) (cdr value) value))
  9. )
  10.
But we  still haven't addressed if there is any merit to such construct as
  (foreach  i  (in_range 0 10 1) ....
ymg
ElpanovEvgeniy
  • Moscow (Russia)
Re: Range Function
« Reply #23 on: November 18, 2013, 05:34:24 AM »
@ ElpanovEvgeniy:
Thank you, I corrected!
  2.   (if (or (and (> i 0) (< s e)) (and (< i 0) (> s e)))
  4.   )
  5. )
ymg
Re: Range Function
« Reply #24 on: November 18, 2013, 06:22:04 AM »
No matter how I try, I don't have the recursive bone in me.
Haven't figured how the first one work, now need to wrap my head around the corrected one.
Still the Best One!!
But, Evgeniy what do you think of construct like the one proposed???
ymg
ElpanovEvgeniy
  • Moscow (Russia)
Re: Range Function
« Reply #25 on: November 18, 2013, 06:36:27 AM »
(foreach i (in_range 0 10 1) [I do not understand what needs to be here] ....
give any example...
Re: Range Function
« Reply #26 on: November 18, 2013, 06:47:12 AM »
An iterative solution perhaps:
  1. (defun range ( s e i / l )
  2.     (repeat (fix (abs (/ (- e s) i)))
  3.         (setq e (- e i) l (cons e l))
  4.     )
  5. )
EDIT: spoke too soon...
  1. _$ (range 0 10 3)
  2. (1 4 7)
Re: Range Function
« Reply #27 on: November 18, 2013, 06:55:37 AM »
A quick fix, but not great  :-(
  2.     (if (< 0 (abs (rem e i)))
  3.         (setq e (+ e (- i (rem e i))))
  4.     )
  5.     (repeat (fix (abs (/ (- e s) i)))
  6.         (setq e (- e i) l (cons e l))
  7.     )
  8. )
ymg
Re: Range Function
« Reply #28 on: November 18, 2013, 07:01:45 AM »
Here is a stupid one:
    (setq tot (+ tot i))
In other word we do not need to increment the index to the loop.
The python boys use it at every sauce.
ymg
« Last Edit: November 18, 2013, 07:11:10 AM by ymg »
ElpanovEvgeniy
  • Moscow (Russia)
Re: Range Function
« Reply #29 on: November 18, 2013, 09:11:00 AM »
ymg
  1. (defun range (s e i f)
  3.     (progn (f s) (range (+ i s) e i f))
  4.   )
  5. )
test:  corrected  (test 0 10 1 0) >> (test 0 10 1 55)
  1. (defun test (s e i tot)
  2.    (range s e i (lambda (a) (setq tot (+ tot a))))
  3.    tot
  4. )
  5.
  6. (test 0 10 1 0) ; >> 45
  7. (test 0 10 1 55) ; >> 100
« Last Edit: November 18, 2013, 10:47:54 AM by ElpanovEvgeniy »
