Author Topic: Count unique items of multidimensional list by member-list  (Read 2056 times)
NICK_VNV
« on: November 13, 2013, 02:42:13 PM »
Here is a useful function made by Lee Mac:
  1. ;; Count Items  -  Lee Mac
  2. ;; Returns a list of dotted pairs detailing the number of
  3. ;; occurrences of each item in a supplied list.
  4.
  5. (defun LM:CountItems ( l / c l r x )
  6.     (while l
  7.         (setq x (car l)
  8.               c (length l)
  9.               l (vl-remove x (cdr l))
  10.               r (cons (cons x (- c (length l))) r)
  11.         )
  12.     )
  13.     (reverse r)
  14. )
  15. ; Example
  16. (LM:CountItems '("A" "B" "B" "B" "C" "C" "D" "E" "E" "E" "E"))
  17. =>  (("A" . 1) ("B" . 3) ("C" . 2) ("D" . 1) ("E" . 4))
  18.
Please show how to modify this function to get the result:
  1.  ; if we have a list
  2.  (setq lst '(
  3.                                 (("a" "1") ("b" "2") ("c" "3")("d" "6"))
  4.                                 (("a" "2") ("b" "4") ("c" "5")("d" "4"))
  5.                                 (("a" "2") ("b" "4") ("c" "5")("d" "2"))
  6.                                 (("a" "3") ("b" "3") ("c" "6")("d" "3"))
  7.                         )
  8. )
  9.
  10. ; new function
  11. (LM:CountItems_by_member  lst  (list "a" "b" "c") )
  12. => (
  13.                 (("a" "1") ("b" "2") ("c" "3")("count" "1"))
  14.                 (("a" "2") ("b" "4") ("c" "5")("count" "2"))
  15.                 (("a" "3") ("b" "3") ("c" "6")("count" "1"))
  16.           )
  17.
Re: Count unique items of multidimensional list by member-list
« Reply #1 on: November 13, 2013, 04:42:41 PM »
Here is a quick hack:
  1. (defun f ( l i / x c r )
  2.     (setq l (mapcar '(lambda ( x ) (vl-remove-if-not '(lambda ( x ) (member (car x) i)) x)) l))
  3.     (while l
  4.         (setq x (car l)
  5.               c (length l)
  6.               l (vl-remove x (cdr l))
  7.               r (cons (append x (list (list "count" (itoa (- c (length l)))))) r)
  8.         )
  9.     )
  10.     (reverse r)
  11. )
  1. (setq lst
  2.    '(
  7.     )
  8. )
  9. _$ (f lst '("a" "b" "c"))
  10. (
  11.     (("a" "1") ("b" "2") ("c" "3") ("count" "1"))
  12.     (("a" "2") ("b" "4") ("c" "5") ("count" "2"))
  13.     (("a" "3") ("b" "3") ("c" "6") ("count" "1"))
  14. )
ribarm
  • Marko Ribar, architect
« Reply #2 on: November 13, 2013, 04:53:57 PM »
slow hack...
  1. (setq lst  '(
  2.               (("a" "1") ("b" "2") ("c" "3") ("d" "6"))
  3.               (("a" "2") ("b" "4") ("c" "5") ("d" "4"))
  4.               (("a" "2") ("b" "4") ("c" "5") ("d" "2"))
  5.               (("a" "3") ("b" "3") ("c" "6") ("d" "3"))
  6.             )
  7. )
  8.
  9. (setq mlst '("a" "b" "c"))
  10.
  11. (defun c_i_b_m ( lst mlst / lsta xlst xlsta ilst lstt x c r )
  12.
  13.   (defun unique ( l )
  14.     (if l (cons (car l) (vl-remove (car l) (unique (cdr l)))))
  15.   )
  16.
  17.   (setq lsta (apply 'append lst))
  18.   (foreach m lsta
  19.     (if (not (member (car m) mlst))
  20.       (setq xlst (cons (car m) xlst))
  21.     )
  22.   )
  23.   (setq xlst (unique xlst))
  24.   (foreach i lst
  25.     (foreach x xlst
  26.       (setq xlsta (mapcar '(lambda (z) (if (eq x (car z)) z)) i))
  27.     )
  28.     (setq xlsta (vl-remove nil xlsta))
  29.     (setq ilst i)
  30.     (foreach x xlsta
  31.       (setq ilst (vl-remove x ilst))
  32.     )
  33.     (setq xlsta nil)
  34.     (setq lstt (cons ilst lstt))
  35.   )
  36.   (setq lstt (reverse lstt))
  37.   (while lstt
  38.      (setq x (car lstt)
  39.            c (length lstt)
  40.            lstt (vl-remove x (cdr lstt))
  41.            r (cons (append x (list (list "count" (itoa (- c (length lstt)))))) r)
  42.      )
  43.   )
  44.   (reverse r)
  45. )
  46.
M.R. on Youtube
NICK_VNV
« Reply #3 on: November 14, 2013, 01:09:21 AM »
Thank you guys for help and quick reply!  :-D
I also tried to make a version of function without counting items (just removing duplicates), and seems it works:
  1. (defun f2 ( l i / x c r )
  3.     (while l
  4.         (setq x (car l)
  5.               c (length l)
  7.               r (cons x r)
  8.         )
  9.     )
  10.     (reverse r)
  11. )
  12.
  13. ;;; example
  14. (setq lst  '(
  15.               (("a" "1") ("b" "2") ("c" "3") ("d" "6"))
  16.               (("a" "2") ("b" "4") ("c" "5") ("d" "4"))
  17.               (("a" "2") ("b" "4") ("c" "5") ("d" "2"))
  18.               (("a" "3") ("b" "3") ("c" "6") ("d" "3"))
  19.             )
  20. )
  21.
  22. _$ (f2 lst '("a" "b" "c"))
  23. (
  24.     (("a" "1") ("b" "2") ("c" "3"))
  25.     (("a" "2") ("b" "4") ("c" "5"))
  26.     (("a" "3") ("b" "3") ("c" "6"))
  27. )
  28.
« Last Edit: November 14, 2013, 01:13:02 AM by NICK_VNV »
