Author Topic: is there a way to select annotative objects for spacific scale?  (Read 1630 times)
HasanCAD
« on: October 20, 2013, 11:32:36 AM »
there are drawings come from the clinent which has a lot of annotative scales.
So, I want to select annotative objects which has spacific scale to delete unwanted scales and/or change to scale which i use.
for example objects which has scale 1:50
Thanks all
HasanCAD
Re: is there a way to select annotative objects for spacific scale?
« Reply #1 on: October 22, 2013, 08:29:19 AM »
Is there no SSGET method for that
pBe
« Reply #2 on: October 22, 2013, 08:54:01 AM »
Not that i know of. I guess there should be, otherwise select all annotative [Text/Mtext/BLocks/Dimensions.....] dig deep using entget until you hit
(3 . "ACDB_ANNOTATIONSCALES") then work from there?
Crank
« Reply #3 on: October 24, 2013, 05:41:19 PM »
Perhaps this is an idea: Add all scales and then remove the ones you don't need:
(defun c:OnlyCScale (/ l3 l4 l5 l6 l7 SS CS n waarden ent lijst AV)
(setq SS (ssget "I"))
(command ".undo" "begin")
;(setq AV (getvar "ANNOALLVISIBLE"))
;(if AutoAnnoAllVisible (setvar "ANNOALLVISIBLE" 1))
(while (not SS)(setq SS (ssget)))
(command ".chprop" ss "" "Annotative" "y" "")
(setq CS (getvar "CANNOSCALE"))
(command "-OBJECTSCALE" SS "" "Add" CS "")
;(setvar "ANNOALLVISIBLE" AV)
(setq n 0 lijst '())
(repeat (sslength SS)
(setq ent (ssname SS n))
(setq waarden (get_ent_scales (entget ent)))
(if waarden (setq lijst (append waarden lijst)))
(setq n (1+ n))
(setq lijst (remove_doubles lijst)); verwijderen dubbelingen
(foreach n lijst; schalen sorteren en verwijderen
(if (/= n CS)(progn
(if (= (strlen n) 3)(setq l3 (vl-sort (cons n l3)'<)))
(if (= (strlen n) 4)(setq l4 (vl-sort (cons n l4)'<)))
(if (= (strlen n) 5)(setq l5 (vl-sort (cons n l5)'<)))
(if (= (strlen n) 6)(setq l6 (vl-sort (cons n l6)'<)))
(if (= (strlen n) 7)(setq l7 (vl-sort (cons n l7)'<)))
(command "-OBJECTSCALE" SS "" "Del" n "")
(setq lijst (append l3 l4 l5 l6 l7))
(princ (strcat "\n\nDeze selectie is voorzien van schaal " CS))
(if lijst (progn
(princ "\nen de volgende schalen zijn verwijderd van deze selectie:")
(foreach n lijst (princ (strcat " " n)))
(command ".undo" "end")
(defun remove_doubles (lst); by Gile
(if lst (cons (car lst) (remove_doubles (vl-remove (car lst) lst))))
(defun get_ent_scales (ent / annotative lijst n schalen collect)
; zie ook: http://www.theswamp.org/index.php?topic=24171.0
(defun collect (key lijst / n return)
(foreach n lijst
(if (= key (car n))
(setq return (cons (cdr n) return))
return
(setq annotative (cdr (assoc 360 ent)))
(if annotative (progn
(setq lijst
(entget (cdr (assoc 350
(entget (cdr (assoc 360
(member '(3 . "AcDbContextDataManager"); Get the right 360-code
(entget annotative)
(foreach n (collect 350 lijst)
(setq schalen (cons
(cdr (assoc 300 (entget (cdr (assoc 340 (entget n))))))
schalen
schalen
HasanCAD
« Reply #4 on: October 27, 2013, 07:49:13 AM »
Thankx Crank
i'll try and tell the result.
