Author Topic: Rotation of Object OR Text  (Read 4741 times)
M-dub
« on: July 11, 2013, 02:11:51 PM »
I have a block that needs to be rotated based on the location of this block, but along with the geometry, I also have an attribute whose rotation angle I would like to remain at 0°.
Part A of my question is Would it be better to put the rotation on the text or on the lines of the block?
Part B is ... how do I do it?  Still haven't ventured very far into Dynamic Blocks.  :oops:
Thanks!
Matt__W
  • I like my water diluted.
Re: Rotation of Object OR Text
« Reply #1 on: July 11, 2013, 02:44:38 PM »
Not sure about the attribute part, but for rotating the block I would use an alignment parameter (see attached DWG).
Autodesk Expert Elite
Nibster
« Reply #2 on: July 11, 2013, 02:52:23 PM »
we ended up using a reactor to keep the attribute's rotation at zero in the blocks that used alignment parameters.
« Reply #3 on: July 11, 2013, 02:53:21 PM »
For a attribute its position must be locked, and agree with Matt on using a alignment parameter.
For a start here is a rotation action for the whole block(lines and symbols) and one for the text only.
M-dub
« Reply #4 on: July 11, 2013, 04:10:42 PM »
Thanks a lot, guys!
Julian.nihon
  • Mosquito
« Reply #5 on: July 12, 2013, 12:33:51 AM »
Try this  :-)
Alignment parameter is good for quickly rotate blocks, but I don't this you can rotate attribute.
So i used a rotate action and move action, then you can rotate the block, and the attribute will follow ...
huhu, it's my first post since i registered  :-o
