Hi danallen,See primarily it helps to reduce the TAT by almost 60% by using acroplot. I suggest you should use it for better accuracy as well. AutoCAD 2014 still does not have features like acroplot.
Quote from: Johnvictor on October 16, 2013, 10:58:14 AMHi danallen,See primarily it helps to reduce the TAT by almost 60% by using acroplot. I suggest you should use it for better accuracy as well. AutoCAD 2014 still does not have features like acroplot. Can you please provide some more details?What is "TAT"?
We're looking at upgrading from ancient 2005 to 2014 and putting a budget together. We use Acroplot to batch print projects, and for the better quality than straight to Adobe PDF driver provides. Is this still necessary in the newer versions of AutoCAD?Dan
