Author Topic: Coordinates along a spline.  (Read 6054 times)
Matokage
« on: June 14, 2013, 01:40:41 PM »
Hello, fellow CADesters.
I'm a young CADist in the roads sector and i'm working doing as build and gathering coordinates for the Topographers. On thing that is hurting my productivity is gather coordinates of various points of the road Axis or Roadside. I was wondering if there is a easy way to get a list of coordinates of a spline (or multiple ones) at a given distance, in my case, I need to gather coordinates from multiple splines along the roadside at each 10 meters, doing it manually is pretty ineffective.
Dave M
Re: Coordinates along a spline.
« Reply #1 on: June 14, 2013, 02:11:58 PM »
You could use the measure command to place points on the spline at a given distance, and then use Lee Mac's Point Manager http://lee-mac.com/ptmanager.html to export the coordinates to a text file.
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
Matokage
« Reply #2 on: June 14, 2013, 02:21:18 PM »
But measure don't place points, does it?  :|
Rob...
« Reply #3 on: June 14, 2013, 02:29:25 PM »
Off topic curiousity question:
Why splines? I would think it would be very hard to generate accurate drawings with them.
CAD Tech
Matokage
« Reply #4 on: June 14, 2013, 02:34:27 PM »
Well, roads are not square so we use splines for a soft and smooth curve, and the topographers... well they know how to make it accurate (even not begin all that accurate), also, we use arcs for those central gardens.
Dave M
« Reply #5 on: June 14, 2013, 03:59:03 PM »
Yes, the measure command will place AutoCAD point objects
Matokage
« Reply #6 on: June 14, 2013, 07:21:15 PM »
Hmm... Actually, I was searching a little bit and found this http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-4a17.htm,topicNumber=d0e266559
Looks like I was using it wrong. Seems exacly what I need, gonna try it monday mourning at work and train a little bit at home this sun day. Thanks for the help   :-)
Edit:
Also, i think that the main problem was my AutoCAD version, it's AutoCAD 2007, I gonna ask my boss for an upgrade next week.
Tryed it now with my 2007 at home and it worked, seems that I really wasn't familiar with this command.
« Last Edit: June 14, 2013, 08:36:45 PM by Matokage »
alanjt
  • Standby for witty remark...
« Reply #7 on: June 14, 2013, 11:28:18 PM »
Since it's close enough to be relevant: be sure to look at the DIVIDE command.
Dropbox
