Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
copy entity from block
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: copy entity from block (Read 10812 times)
Seagull
London, England
WWW
Re: copy entity from block
Reply #15 on:
June 04, 2013, 09:57:37 AM »
Quote from: Ketxu on June 04, 2013, 09:47:21 AM
Oh now i see ^^ Great, It's new for me.
You're welcome!
I also use this construct when retrieving Object IDs, as shown by my
LM:ObjectID
function in
this program
Lee
Logged
Lee Mac Programming
Twitter
Exchange App Store
ahsattarian
Newt
Reply #16 on:
October 12, 2023, 02:49:09 AM »
Have a look at this routine below.
It copies Line from inside Block into Current Space.
Code - Auto/Visual Lisp:
[Select]
defun
c:ncopyline
while
t
setq
g
1
while
g
1
while
null
setq
es
nentselp
\r
Select Line : "
setq
s
car
es
setq
en
entget
s '
setq
typ
strcase
cdr
assoc
0
en
t
cond
typ
"line"
setq
g
0
setq
en
entget
s '
setq
po1
cdr
assoc
10
en
setq
po2
cdr
assoc
11
en
setq
li
list
po1 po2
foreach
s
cadddr
es
setq
en
entget
s '
setq
po
cdr
assoc
10
en
setq
scx
cdr
assoc
41
en
setq
scy
cdr
assoc
42
en
setq
scz
cdr
assoc
43
en
setq
ang
cdr
assoc
50
en
setq
ocs
cdr
assoc
210
en
setq
method1
2
cond
method1
1
;| Written by : Lee Mac |;
defun
mxv
m v
mapcar
lambda
r
apply
mapcar
r v
m
defun
trp
m
apply
mapcar
cons
list
m
defun
mxm
m n
lambda
a
mapcar
lambda
r
mxv a r
m
trp n
setq
li1 '
1.0
0.0
0.0
0.0
1.0
0.0
0.0
0.0
1.0
setq
li2
list
list
cos
ang
sin
ang
0.0
list
sin
ang
cos
ang
0.0
0.0
0.0
1.0
setq
li3
list
list
scx
0.0
0.0
list
0.0
scy
0.0
list
0.0
0.0
scz
setq
mat
mxm
mapcar
lambda
v
trans
v
0
ocs t
li1
mxm li2 li3
setq
li4
mxv mat
cdr
assoc
10
tblsearch
"block"
cdr
assoc
2
en
setq
rfg
list
mat
mapcar
trans
cdr
assoc
10
en
ocs
0
li4
setq
li
apply
function
lambda
m v
mapcar
function
lambda
p
mapcar
mxv m p
v
li
rfg
method1
2
;| Written by : Amir Hossein Sattarian |;
setq
li
mapcar
lambda
pt
mapcar
pt
list
scx scy scz
li
setq
li
mapcar
lambda
pt
polar
0
0
0
ang
angle
0
0
0
pt
distance
0
0
0
pt
li
setq
li
mapcar
lambda
pt
mapcar
pt po
li
setq
li
mapcar
lambda
pt
trans
pt ocs
0
li
setvar
"cmdecho"
0
command
"line"
trans
car
li
0
1
trans
cadr
li
0
1
command
"pselect"
"last"
princ
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
