Quote from: CottageCGirl... The FIND/REPLACE commands dont work because they "FIND" the seqence of numbers in ALL of the attributes (not just room#) and "REPLACE" messing up all the blocks (found out that one the hard way)HELP...... [/url]Actually, although the default behavior for find/replace is to work on the entire drawing, you can select entities and have it work only on those entities. Just click the button in the dialog to the right of where it says "Entire drawing."
