Not sure, but this is my try...P.S. Make sure after you used it to disable it with (vlr-remove-all) or (vlr-remove Cmnd_Reac)...Code - Auto/Visual Lisp: [Select](vl-load-com) (defun commandEnded ( reac data ) (if (eq (car data) "MSPACE") (setvar 'navvcubedisplay 0) )) (setq Cmnd_Reac (vlr-command-reactor "Command reactor: " (list '(:VLR-commandEnded . commandEnded) ) ))
