Author Topic: How to work user input for this program  (Read 7229 times)
Adesu
« on: March 17, 2005, 12:54:20 AM »
The scenario for this program,is if in your area drawing there are string,as like 10 20 30 40 .....etc,now you please click 10 20 etc,then the program would ask,what you want to do ( "Select Add Subtracts Divides Multiply"),then ask again where you would put for text in area drawing,the result final would display as gave them input,but in "opt" this program can't work,anyones can help how to solve this script,thanks. :(
; cco is stand for create count object
;        Design by Ade Suharna <mteybid@yuasabattery.co.id>
;        15 March 2005
;        Program no.213/03/2005
;        Edit by
(defun c:cco (/ ss ssl cnt ssn opt ttl)
  (prompt "\nCLICK OBJECT TO BE EVALUATION")
  (setq ss (ssget))
  (setq ssl (sslength ss))
  (setq cnt 0)
  (repeat ssl
    (setq ssn (ssname ss cnt))
    (setq sse (entget ssn))
    (setq as1 (atoi (cdr (assoc 1 sse))))
    (set (read (strcat "ss" (itoa cnt))) as1)
(prompt "Select Add Subtracts Divides Multiply")
(initget " A S D M ")
(setq opt (getkword "\nCHOOSE ONES <A/S/D/M>: "))
(cond ((eq opt "A")(setq opt +))
      ((eq opt "S")(setq opt -))
      ((eq opt "D")(setq opt /))
      ((eq opt "M")(setq opt *))
(if ss
    ((eq ssl 1)(alert "\nInvalid selected,not enough to evaluation"))
    ((eq ssl 2)(setq ttl (opt ss0 ss1)))
    ((eq ssl 3)(setq ttl (opt ss0 ss1 ss2)))
    ((eq ssl 4)(setq ttl (opt ss0 ss1 ss2 ss3)))
    ((eq ssl 5)(setq ttl (opt ss0 ss1 ss2 ss3 ss4)))
    ((eq ssl 6)(setq ttl (opt ss0 ss1 ss2 ss3 ss4 ss5)))
    ((eq ssl 7)(setq ttl (opt ss0 ss1 ss2 ss3 ss4 ss5 ss6)))
    ((eq ssl 8)(setq ttl (opt ss0 ss1 ss2 ss3 ss4 ss5 ss6 ss7)))
    ((eq ssl 9)(setq ttl (opt ss0 ss1 ss2 ss3 ss4 ss5 ss6 ss7 ss8)))
    ((eq ssl 10)(setq ttl (opt ss0 ss1 ss2 ss3 ss4 ss5 ss6 ss7 ss8 ss9)))
    ((> ssl 10)(alert "\nSorry your selected,too over"))
  (setq loc (getpoint "\nCLICK LOCATION FOR RESULT OBJECT: "))
  (setq hei 1)
  (command "_text" loc hei "" ttl "")
  (princ ttl)
« Reply #1 on: March 17, 2005, 01:04:23 AM »
Adesu,
Do you know how to use the debugger in the Visual Lisp IDE ?
« Reply #2 on: March 17, 2005, 01:11:26 AM »
It would help anyone testing or using this if this line
read
(prompt "\nSelect TEXT to be evaluated.")
... I assume it's text because of this : (assoc 1 sse)
Is it meant to select text ??
added : and is the value meant to be a string representation of an integer
« Reply #3 on: March 17, 2005, 01:44:02 AM »
I have made some serious assumptions here :
look for these markers
;; added kwb
;; revised kwb
Particularly these :
The cnt variable for the ssNo  was not being incremented in the repeat loop
;; revised kwb : quoted the additive and multiplicative symbols
;; revised kwb : changed (setq ttl (opt ....)
;; to ((eval opt) ss0 ss1 ... ... ... )))
;;revised as noted : kwb@theSwamp
  ;; revised kwb
  ;;(prompt "\nCLICK OBJECT TO BE EVALUATION")
  ;; /revised kwb
  (setq ss  (ssget)
        ssl (sslength ss)
        cnt 0
  (repeat ssl
          sse (entget ssn)
    ;; added kwb
    (setq cnt (1+ cnt))
    ;;/added
  (cond ((eq opt "A") (setq opt '+))
        ((eq opt "S") (setq opt '-))
        ((eq opt "D") (setq opt '/))
        ((eq opt "M") (setq opt '*))
  ;; /revised kwb :
  (if ss
      ((eq ssl 1) (alert "\nInvalid selected,not enough to evaluation"))
      ((eq ssl 2) (setq ttl ((eval opt) ss0 ss1)))
      ((eq ssl 3) (setq ttl ((eval opt) ss0 ss1 ss2)))
      ((eq ssl 4) (setq ttl ((eval opt) ss0 ss1 ss2 ss3)))
      ((eq ssl 5) (setq ttl ((eval opt) ss0 ss1 ss2 ss3 ss4)))
      ((eq ssl 6) (setq ttl ((eval opt) ss0 ss1 ss2 ss3 ss4 ss5)))
      ((eq ssl 7) (setq ttl ((eval opt) ss0 ss1 ss2 ss3 ss4 ss5 ss6)))
      ((eq ssl 8) (setq ttl ((eval opt) ss0 ss1 ss2 ss3 ss4 ss5 ss6 ss7)))
      ((eq ssl 9) (setq ttl ((eval opt) ss0 ss1 ss2 ss3 ss4 ss5 ss6 ss7 ss8)))
      ((eq ssl 10)(setq ttl ((eval opt) ss0 ss1 ss2 ss3 ss4 ss5 ss6 ss7 ss8 ss9)))
      ((> ssl 10) (alert "\nSorry your selected,too over"))
  ;; /revised kwb :
  ;; revised kwb
;;;  (setq loc (getpoint "\nCLICK LOCATION FOR RESULT OBJECT: ")
;;;        hei 1
  (setq loc (getpoint "\nSelect Location for New Text : ")
        hei 1
  ;; /revised kwb
  ;; revised kwb
;;;  (command "_text" loc hei "" ttl "" "")
  (command "_text" loc hei "" ttl 0)
  ;; /revised kwb
  (princ ttl)
« Reply #4 on: March 17, 2005, 02:00:11 AM »
.. and just a courtesy note .. can you please add code tags to your posts, they make the code more readable .. well for me anyway.
If you dont know how, please ask.
Adesu
« Reply #5 on: March 17, 2005, 03:51:44 AM »
Quote from: Kerry Brown
.. and just a courtesy note .. can you please add code tags to your posts, thet make the code readable .. well for me anyway.
Hi Kerry Brown,after your revised,that code become work,perfect !!,thanks a lot for your suggest.
I am not understanding what do you mean "can you please add code tags to your posts, thet make the code readable",can you more detail for this your argument,sorry for rather stupid my question
« Reply #6 on: March 17, 2005, 04:06:06 AM »
Quote from: Adesu
Have a look here Adesu. http://www.theswamp.org/phpBB2/faq.php?mode=bbcode#5
Adesu
« Reply #7 on: March 17, 2005, 04:22:39 AM »
Quote from: Mark Thomas
Quote from: Adesu
Hi Mark ,thanks for your suggest,sorry for post before,because I new in this forum,especialy for posting.
by the way,are you not yet sleeping for this time ?
« Reply #8 on: March 17, 2005, 04:56:29 AM »
Quote from: Adesu
Nope, not sleeping.  :cry:   It is going to be a long day!!
« Reply #9 on: March 17, 2005, 07:01:49 AM »
I feel your pain brother, sorry to hear it.
« Reply #10 on: March 17, 2005, 08:12:09 AM »
Quote from: Adesu
>>> ,after your revised,that code become work,perfect !!,thanks a lot for your suggest. <<<<
You're welcome.
Good to see you got the code tags working too. :)
Stay well,
daron
« Reply #11 on: March 17, 2005, 08:14:22 AM »
Oops! I edited his post and added the code tags, so it could be read.
« Reply #12 on: March 17, 2005, 08:37:37 AM »
Perhaps view this instruction Adesu.
Cheers.
« Reply #13 on: March 17, 2005, 08:37:49 AM »
most excellent Daron.
kwb
Adesu
« Reply #14 on: March 17, 2005, 07:58:43 PM »
Quote from: MP
Cheers.
Hi Daron and MP,thanks very much for your tutorial and suggest,it mean if we send thread ,as like this
(defun.....bla..bla...
sorry if my question too stupid,what function your add [code] at begin and finish text?
