Author Topic: [2013] Civil 3D pipe elbows  (Read 2058 times)
Matt__W
  • I like my water diluted.
« on: March 12, 2013, 10:18:22 AM »
Is there a way to make the pressure pipe elbows appear solid like the pipe in the attached image?  I'm trying to create a "presentation" style which is essentially thick lines so the systems show clearly when plotted out for P&Z meetings.
Thoughts?  Suggestions?
Autodesk Expert Elite
Re: [2013] Civil 3D pipe elbows
« Reply #1 on: March 15, 2013, 07:30:34 AM »
two options:
USER DEFINED BLOCKS (solids)
or set the view to something just 'off' pan view, and use the 3d representation of the fitting(s)
