Could you comment further on what FDOT does to modify non-FDOT profiles?
Firstly, the most recent release comments I provided FDOT was back in January 2013... All 14 pages of comments, code snippets, and screenshots, specifically regarding session start, workspace, and registry - not even beginning to touch the actual plans production process (
using your tools), or tax payer funded
Sheet Set Organizer application.
I have not tested another release since then for reasons not discussed here. Should any of the concerns to follow be already corrected, improved, etc. please take from these comments what is applicable only. You can download the most recent release here (
issued 04/30/2013):
http://www.dot.state.fl.us/ecso/downloads/publications/civil3dworkflows/default.shtm... But you knew that already, didn't you??? LoL
... As to your question, Mike R. (
FDOT CADD Applications Developer):
Consider the FDOT Profile (
.ARG), which loads myriad registry changes, and saves to the 'Civil 3D' workspace (
stored in main CUIx, and applies to all Profiles), rather than creating a workspace of your own (
stored in your own CUIx)... Which in and of itself is ironic, given that you implement the FDOT Ribbon via .NET plug-in (
which is/was inefficient, had typo(s) in it, etc.), rather than CUIx, which precludes one's ability to save role-specific Ribbon components (
i.e., technician, designer, etc.) to one's own workspace... Instead, one is relegated to using your Ribbon the way FDOT (
you) have poorly chosen to implement it.
Further,
Aecc*FloridaDOT registered applications have been added to the core product in lieu of being loaded only as part of an FDOT plug-in project, which means these applications are being loaded into each-and-every-session no matter if one is working on an FDOT project, or a California private client project... This is simply not necessary, and takes additional time at session start to load them (
regardless of one's computer hardware configuration performance).
Given the advent of Autoloader starting in 2012 products, I personally feel that FDOT's plug-in should be made available in the form of an Autoloader .bundle (
demand-loaded, based on the CPROFILE system variable) and published at Autodesk Exchange... I have much more faith in ADN staff than FDOT's developers, and that's saying something.
Thanks for your time, and consideration.
Cheers
