I need to set the lookup parameter of a dynamic block.
I can get the block using (and if anyone can tell me how to get an selection set without zooming, I'd be very grateful)
(CHGDYNPROP
(ssname SSet
0) "Lookup1" Lookup
and then run it through the routine
(defun CHGDYNPROP
(Ename propname newval
/ obj v vval sal tot i
) ;; Changes a given variable in your block
;; Passed: Ename, Property Name, New value for Property
Ename
v (vla-getdynamicblockproperties obj)
sal
(vlax
-safearray
->list vval
) i 0)
This all work great as long as the block is in a location I can zoom to and then grab. The problem is when it has been moved to a different location on the screen.
This doesn't work because the block's name has changed to an anonymous block name:
(SSGET "X" '
((2 .
"BLOCKNAME")))
I've tried this:
(= :vlax-true (vla-get-IsDynamicBlock block))
(CHGDYNPROP block "Lookup1" Lookup)
);if
);vlax-for
);defun
I can find the block okay, I think. When I inspect the variable "block" it says its a VLA-OBJECT |AcadBlock. I try to get info on different parts and I get errors. Since the subroutine will accept enames, I tried (vlax-vla-object->ename block) and it returns the ACAD BLOCK_RECORD. I don't know how to handle this.
What is the way to get this block in a form that I can use the CHGDYNPROP subroutine to set the lookup parameter?
Thanks,
Rabbit
