Author Topic: Variables in String  (Read 2084 times)
bchapman
Variables in String
« on: February 09, 2013, 12:29:51 AM »
Can someone please show me how to pass variables in a string. I'm using the following with SendCommand() method but I want the coordinate and the Attribute to be values I collected.  Thanks!
string strSend = "-insert ELVTAG \n 0,0 1 45 \n ";
Re: Variables in String
« Reply #1 on: February 09, 2013, 03:47:53 AM »
If I understand your request correctly :
You'd need to evaluate the variables in the routine and concatenate the values into the string.
bchapman
« Reply #2 on: February 09, 2013, 03:51:41 AM »
I have the values stored in variables... I just need to figure out how to get them into the string I'm using below in my SendCommand()
string strSend = "-insert ELVTAG \n" + COORD + " 1 45 \n ";
is ^ correct? If not what's the right format?
« Last Edit: February 09, 2013, 03:59:38 AM by BC_in_NV »
« Reply #3 on: February 09, 2013, 03:54:10 AM »
you'll need to convert the value to a string I think.
Should be easy to test.
bchapman
« Reply #4 on: February 09, 2013, 04:14:54 AM »
That was the trick, thanks for sending me on the right path :)
I'm rewriting my lisp library I've developed over 10 years in c#... this is painful lol...
Thanks again for the help
« Last Edit: February 09, 2013, 04:24:46 AM by BC_in_NV »
WILL HATCH
« Reply #5 on: February 11, 2013, 11:35:19 AM »
A more elegant way of doing this is using
Code - C#: [Select]
  1. String.Format("-insert ELVTAG \n{0} 1 45 \n ", COORD);
  2.
otherwise you can create the block reference on your own and do the whole thing behind the scenes
TheMaster
« Reply #6 on: February 11, 2013, 12:10:10 PM »
If you followed the advice that Gile offered in another thread regarding using the Editor's RunCommand() method, you wouldn't have this problem because unlike SendCommand(), RunCommand() doesn't require you to convert command input to strings.
The RunCommand() method is the direct equivalent of the LISP (command) function, and like the latter, it accepts numbers, points, selection sets, entity names (ObjectIds in managed code), and so on.
