Author Topic: < Challenge > Integers into words / Ordinal Numbers into words  (Read 23327 times)
Re: < Challenge > Integers into words / Ordinal Numbers into words
« Reply #30 on: February 13, 2013, 05:43:12 PM »
Wow ... once I saw your code I though: How simple! (read as compliment  ;) ) I could've kicked myself for not getting to that half-functional / half-imperative but iterative method!
Thanks Irne!  :-)
I'm now thinking, what about other more convoluted numbering systems? Say the Babilonian system?
Nice idea! - here is my Babylonian function (assuming I have understood the system correctly):
(defun LM:int->babylonian ( n )
    (if (< n 60)
        (strcat (substr "<<<<<" 1 (/ n 10)) (substr "TTTTTTTTT" 1 (rem n 10)))
        (strcat (LM:int->babylonian (/ n 60)) " " (LM:int->babylonian (rem n 60)))
_$ (LM:int->babylonian 424000)
"T <<<<<TTTTTTT <<<<TTTTTT <<<<"
« Last Edit: February 13, 2013, 06:08:18 PM by Lee Mac »
irneb
« Reply #31 on: February 13, 2013, 05:59:48 PM »
Good one! Slight correction though:
  1. (defun LM:int->babylonian ( n )
  2.     (if (< n 60)
  3.         (strcat (substr "<<<<<" 1 (/ n 10)) (substr "TTTTTTTTT" 1 (rem n 10)))
  4.         (strcat (LM:int->babylonian  (/ n 60)) " " (LM:int->babylonian  (rem n 60)))
  5.     )
  6. )
But it works!
I'm just in 2 minds about the use of spaces. It's a bit difficult to figure out if "T " (60) or "T  " (3600) is the same thing.
« Reply #32 on: February 13, 2013, 06:07:24 PM »
Good one! Slight correction though  < ... >
Oops! That'll teach me to modify code in the forum post box... code updated above.
Thanks Irne!
True - I saw that point noted in the article but wanted to emulate the Babylonian system as they described.  :-)
irneb
« Reply #33 on: February 13, 2013, 06:17:25 PM »
Actually again, your code's inspired me to get to a much more succinct algorithm (the iterative version of yours):
  1. (defun IB:Int->Babylonian (num / result)
  2.   (setq result "")
  3.   (while (> num 0) (setq result (strcat " " (substr "<<<<<" 1 (fix (/ num 10)))
  4.                                         (substr "TTTTTTTTT" 1 (fix (rem num 10))) result)
  5.                          num (/ num 60)))
  6.   (vl-string-left-trim " " result))
« Reply #34 on: February 13, 2013, 06:24:44 PM »
Careful Irne...
_$ (IB:int->babylonian 60)
"T <<<<<"
_$ (IB:int->babylonian 70)
"T <<<<<"
_$ (IB:int->babylonian 80)
"T <<<<<"
I would write the iterative version as:
(defun LM:int->babylonian-i ( n / d r )
    (setq r "")
    (while (< 0 n)
        (setq d (rem n 60)
              r (strcat " " (substr "<<<<<" 1 (/ d 10)) (substr "TTTTTTTTT" 1 (rem d 10)) r)
              n (/ n 60)
    (vl-string-left-trim " " r)
« Last Edit: February 13, 2013, 06:41:49 PM by Lee Mac »
« Reply #35 on: February 13, 2013, 06:56:50 PM »
How about Mayan  :lol:
(defun LM:int->mayan ( n )
    (if (zerop n) "0"
        (if (< n 20)
            (strcat (substr "····" 1 (rem n 5)) (substr "|||" 1 (/ n 5)))
            (strcat (LM:int->mayan (/ n 20)) " " (LM:int->mayan (rem n 20)))
_$ (LM:int->mayan 5125)
[ Read with head tipped sideways ]
nobody
  • .net stuff
« Reply #36 on: February 13, 2013, 09:02:55 PM »
lol
pBe
« Reply #37 on: February 14, 2013, 01:53:48 AM »
I applaud each and everyone who participated on this challenge. even the "klingon" inspired conversion.
Hats off to you guys
I learned a lot.
Thank you very much.  :)
irneb
« Reply #38 on: February 14, 2013, 03:09:48 AM »
Careful Irne...
Good catch! Thanks Lee.
« Reply #39 on: February 14, 2013, 09:45:56 AM »
Careful Irne...
No worries!  :-)
Another, for fun: Morse
(defun LM:int->morse ( n )
    (if (< n 10)
        (substr "-----·····-----" (- 11 n) 5)
        (strcat (LM:int->morse (/ n 10)) " " (LM:int->morse (rem n 10)))
or:
    (substr
        (apply 'strcat
            (mapcar '(lambda ( n ) (strcat " " (substr "-----·····-----" (- 59 n) 5)))
                (vl-string->list (itoa n))
        2
_$ (LM:int->morse 2013)
pBe
« Reply #40 on: February 14, 2013, 10:58:28 AM »
you should add "mind-reading" on your set of skills Lee, as that would have been my next challenge. <decrypting  morse code>
Good times LM
« Reply #41 on: February 14, 2013, 11:48:21 AM »
Good times LM
:lol:
Though, unfortunately general alphabetical Morse code isn't as interesting, since it doesn't follow a pattern like the Morse code for the integers...
Here are two very quickly written conversion functions:
(defun words->morse ( s )
    (substr
        (apply 'strcat
            (mapcar
                (function
                    (lambda ( a )
                        (if (setq a (cadr (assoc a morsetable)))
                            (strcat " " a)
                (vl-string->list (strcase s))
        2
(defun morse->words ( s / f )
    (defun f ( s l / c p )
            (   (wcmatch s "   *")
                (cons 32 (f (substr s 4) l))
            (   (setq p (vl-string-position 32 s))
                (if (setq c (cadr (assoc (substr s 1 p) l)))
                    (cons c (f (substr s (+ 2 p)) l))
            (   (setq c (cadr (assoc s l)))
                (list c)
    (vl-list->string (f s (mapcar 'reverse morsetable)))
(setq morsetable
        (32 "  ")
        (65 "·-")
        (66 "-···")
        (67 "-·-·")
        (68 "-··")
        (69 "·")
        (70 "··-·")
        (71 "--·")
        (72 "····")
        (73 "··")
        (74 "·---")
        (75 "-·-")
        (76 "·-··")
        (77 "--")
        (78 "-·")
        (79 "---")
        (80 "·--·")
        (81 "--·-")
        (82 "·-·")
        (83 "···")
        (84 "-")
        (85 "··-")
        (86 "···-")
        (87 "·--")
        (88 "-··-")
        (89 "-·--")
        (90 "--··")
_$ (words->morse "THE SWAMP")
_$ (morse->words (words->morse "THE SWAMP"))
"THE SWAMP"
StykFacE
« Reply #42 on: February 14, 2013, 12:19:14 PM »
I have a mathematics degree...   :-)
THAT explains it!!  :kewl:
Dilan
« Reply #44 on: December 14, 2018, 11:38:36 PM »
Here is my version:
(defun LM:int->words ( n / f1 f2 )
    (defun f1 ( n )
        (if (< n 20)
            (nth (fix n) '("" "one" "two" "three" "four" "five" "six" "seven" "eight" "nine" "ten" "eleven" "twelve" "thirteen" "fourteen" "fifteen" "sixteen" "seventeen" "eighteen" "nineteen"))
            (strcat (nth (- (fix (/ n 10)) 2) '("twenty" "thirty" "forty" "fifty" "sixty" "seventy" "eighty" "ninety")) " " (f1 (rem n 10)))
    (defun f2 ( n l )
            (   (null l) (f1 n))
            (   (< n (caar l)) (f2 n (cdr l)))
            (   (vl-string-right-trim " " (strcat (f2 (fix (/ n (caar l))) (cdr l)) " " (cadar l) " " (f2 (rem n (caar l)) (cdr l)))))
    (if (zerop n)
        "zero"
            (f2 n
                    (1e18 "quintillion")
                    (1e15 "quadrillion")
                    (1e12 "trillion")
                    (1e09 "billion")
                    (1e06 "million")
                    (1e03 "thousand")
                    (1e02 "hundred")
Nice challenge pBe  :-)
Hello!
And how to make words-> int?
From "twenty one thousand five hundred thirty seven" in 21537.
For example.
