Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Convert Images to OLE Objects
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Convert Images to OLE Objects (Read 5611 times)
Dave M
Newt
on:
January 31, 2013, 06:16:01 PM »
I am archiving a bunch of files, and would like to be able embed the images as OLE objects. Just wondering if anyone has a way to do it programmatically?
Logged
Civil 3D 2018 - Microstation SS4 - Windows 10 -
Dropbox
irneb
Water Moccasin
ACad R9-2016, Revit Arch 6-2016
WWW
Re: Convert Images to OLE Objects
Reply #1 on:
February 01, 2013, 01:58:40 AM »
It's probably an incredibly complex lisp interacting with possibly external programs. Might be easier doing this through C#.
But I can't understand why you want to do this. Setup an eTransmit setting to only save (not ZIP) and use folder structures correctly. Then create a Script file to perform this on multiple DWGs. That way all the images / xrefs / whatnot is repathed to a new copy made in the folder structure as specified in the transmittal setup. And the repathing is done to relative paths, so you can copy/move that wherever you want as long as you copy/move the whole set in one go.
That's the way we did archiving since 2005. Never had an issue with anything thus far.
Logged
Dave M
Newt
Reply #2 on:
February 01, 2013, 12:29:47 PM »
That's normally what I do also, but this client wants all the xrefs, etc. bound (not sure why). I'm not going to spend too much time trying to figure it out. They may just have to deal with having the images as-is.
Logged
Dropbox
JAY
Newt
Reply #3 on:
June 02, 2015, 03:30:59 AM »
No quick way ?
Logged
trogg
Bull Frog
WWW
Reply #4 on:
June 02, 2015, 03:07:29 PM »
Here is the manual way to do it.
http://autocadtips1.com/2013/02/22/embed-a-picture-not-as-a-reference/
According to this LINK
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Embed-a-raster-image-in-a-drawing.html
and from what I tested - If you have Raster Design and the images are BITONAL, you can simply open the drawing with RD and use the EMBED command and the bitonal images will now be embedded in the drawing
~Greg
Last Edit: June 02, 2015, 03:18:43 PM by trogg
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
